For those who know: our system consists of 4 old-but-trusty w-bin bass boxes (rated 800W each), 2 Cerwin Vega "Earthquake" bass horns (1.2kW each) and 2 Cerwin Vega 3-way tops (full range), also 1.2kW each. The (cheap) amplifiers we use are powerfull, but not known for their punchiness, so I had to compensate for that as well.
I ran everything at 96kHz/1msec latency. Crossover to the different amplifiers was done by Creamware (12dB/oct sounded best), as well as seperate processing for *each* amplifier channel!
This processing (for each amplifier channel) consisted of 31 band graphic EQ, 4 band parametric EQ, 4 band multiband compression/expansion (Optimaster), low/high enhancement (PsyQ), limiter set just below amplifier clipping level(with long release, thus working as a leveler). The channels feeding our bass-amplifier also had a bit of SPL Transient Designer on it to allow for tighter release. This especially worked great on the w-bins, which tend to be a bit 'lazy' and 'slow' at very low frequencies. The Transient designer compensated for this sluggish response, resulting in a tight bass.
The mid/high speakers were delayed a couple of samples to compensate for the longer signal route of the bass speakers caused by it design (time alignment), allowing for even tigher bass perception (no 'lag'). I did this by ear rather than calculating the time difference.
Input from the DJ mixer to Creamware went through an inexpensive Behringer compressor, set as leveler (ratio at "limiter" and with long release) to protect the A/D from over-enthusiastic DJ's. Output to the amplifiers went through CW analogue out (mid/high) and aditional D/A at the ADAT-port (@ 96kHz) for the lows.
The result: extremely warm yet tight sound. Bright but easy highs (you could even talk in front of the speakers), detailed mid, and thundering lows. A bit like hifi, but than at PA-level
A/B-ing the system with/without Creamware processing is a bit like comparing Yoko speakers to the newest active studio monitors.
A/B-ing 48kHz and 96kHz was very audible (better stereo, silk-like highs at 96kHz) so I decided to go for 96kHz.
Of course a 21 DSP system is a luxury to enhance a relatively inexpensive PA system, but I have my Creamware system anyway so why not use it outside the studio!
The 'winners' of this setup were Optimaster and PsyQ (in that they made the greatest difference). But really, all of the effects had their function and I really doubt I will ever dare to process a PA system *without* creamware anymore!
OK just wanted to share my enthousiasm
[edit] by the way the party was steamin' beyond sunrise
<font size=-1>[ This Message was edited by: [email protected] on 2004-12-12 12:40 ]</font>
