How to resolve a delay problam in logic audio?
Amitos
Post by Amitos »
Hi... I'm working with logic audio, and when I record audio theres an irritating delay between what I play and what i hear. does some1 know how can I fix the problem?
Amit
borg
Post by borg »
well, it would be nice to know how you route the audio and how you monitor...
the first thing to look at, however... what are your ULLI settings? if you can't get your latency down to an acceptable level, you should consider monitoring the direct signal, rather than the ASIO signal (double latency for the stuff your recording).
i hope that does make sense somehow.
andy
the lunatics are in the hall
what drivers are you using? what ulli setting?
