Vinco
Music Manic
Post by Music Manic »
Could someone explain the input threshold please and give ballpark figures on threshold?
Does signal need to be hot?Get very low level.
blazesboylan
Post by blazesboylan »
Well... The Vinco is modelled on the old 1176 limiter. You can read the excellent 1176 manual here:
Urei 1176LN manual
It discusses approaches to using the outboard unit, as well as technical details. Vinco should be technically very similar, with a "modernized" interface (for example, the Attack knob increases attack time when you turn it clockwise).
Beyond that it's really a matter of taste. I generally push the input meter 'til it never (or rarely ever) crosses the 0 threshold. Then I adjust the output meter until it crosses 0 but never turns the clip light on.
However this is a "tune to taste" thing.
Also weak input levels are never a good thing since you'll hear noise floor pretty quickly going through any compressor.
Cheers,
Johann
