Hi.
I own a Pulsar I and is about to update my setup with a Powersampler card. But i'm not sure wether i will be able to use all the ins and outs on both cards at the same time (=2 MIDI, 2 S/P-DIF, 4 analog and 32 ADAT)? Are there any limitations, in the PulsarI/Powersampler combo? Will i get ULLI-possibilities on the old Pulsar?
one happy pulsar-user
BoogieD
Pulsar I and Powersampler - multiple ins and outs?
Guest
Subject: Re: Pulsar I and Powersampler - multiple ins and outs?
Your question:
>>>I own a Pulsar I and is about to update my setup with a Powersampler card. But i'm not sure wether i will be able to use all the ins and outs on both cards at the same time (=2 MIDI, 2 S/P-DIF, 4 analog and 32 ADAT)? Are there any limitations, in the PulsarI/Powersampler combo? Will i get ULLI-possibilities on the old Pulsar?<<<
They Combo would work fine! You will get all I/Os form both cards, better ULLI which is specified on the PS-card documentation (PowerSample as PCI master). And in additional, you will get the two cards work same pulsar V2.04a software environment. As for me, I would have the pulsarII-SRB (with or without I/O as optional) which having about double DSP-power, it's worth as the pricewise!
Someone please correct me if I'm wrong!
Hope this helps,
Long
Your question:
Hope this helps,
Long
