Vendors out of p4p800!! which mobo?
Bosqoue!
Post by Bosqoue! »
That's exactly what has happenend. I can't find any vendors in Denmark who sells the Asus p4p800! So now im wondering which mobo?
Should i pick another mobo from the Asus p4p series or should i go for an Intel d865perl? There are three different perl models at my favourite vendor though. The difference is which controller is used for storage. I don't really know which one to choose. I'm still going to use my old HD (which i think is ATA-66 or 100), but im going to buy some new ones at some point. Is the serial ATA 150 backward compatible? Or i there just some Asus board to go for? As you can see, i'm a bit confused since the disapperance of my beloved p4p800... I hope you guys can help me a bit here!
BTW im going for an intel p4 3ghz and 1gb corsair Twin-X ram.
Bosqoue!
the serial ata is in addition to regular ata connectors.....just get the basic d865perl. if you need lan, the model is d865perll...(2 Ls)
lysergide
Post by lysergide »
garyb i too looking to get the 865perl, although i've heard good things about the 875pbz...
what is the advantage of the 875 over 865 chipset? I as a rule tend to prefer the "newer" and i also read alot of people's posts on Planetz here that use the 875 without any problems whatsoever..
Ricardo
Post by Ricardo »
Happy PBX875 user here! The only thing is don't use onboard LAN. The PERL 865 (one L) is also excellent. I was going to get that but my CW dealer suggested the 875, and it's been rock solid.
R
lysergide, both will work fine. the 865 board works flawlessly and it is about $40 cheaper.....
