Is a 4200rpm hdd fast enough for audio streaming?
petal
Post by petal »
I'm about to buy myself a laptop. The only problem with the one I'm looking at is that it might have a "slow" hdd. So what is your opinion about this. I seldom stream more than 10 audio tracks at a time, is a 4200rpm fast enough then?
Thomas :smile:
<font size=-1>[ This Message was edited by: petal on 2004-09-16 06:02 ]</font>
bassdude
Post by bassdude »
Is that 10 stereo or 10 mono? 10 stereo you might have abit of trouble. :smile:
Counterparts
Post by Counterparts »
It might be worth checking the following aspects of the HDD specs:
seek time - needs to be < 10ms, typically
data transfer rate(s) - burst & continuous
(sorry, can't give specific numbers - will investigate)
Just because the disk spins proportionally slower than a 7,200 (or higher) rpm speed doesn't necessarily mean that the data will be read that much slower - it depends on how the HDD has organised the data on the disk with respect to its spin speed, the number of read/write heads, buffering etc.
It does sound a bit 'old tech' though - do you have an opportunity to try it out before commiting?
Royston
petal
Post by petal »
Thanks for responding!
Well, it might be stereo-tracks....
No I havn't got a chance to try it out before I buy, at least not with a sequencer installed.
The laptop in question is a HP Compaq Business Notebook Nx7010 comparable to this one:
http://www.hp.ca/products/static/notebo ... /index.php
hmmm... Maybe I should check if I can upgrade the HDD to a faster model...!?
Counterparts
Should just be a standard 2.5" IDE drive - I'm pretty sure that you could upgrade it.
(Worth checking first though!)
Royston
petal
Post by petal »
Ok, I went for this baby:
http://h10010.www1.hp.com/wwpc/uk/en/ho ... 20803.html
Pentium M 735 (1,7 Mhz, 2MB level2 cahce)
512 MB (pc2700)
60 GB (4200 rpm)
15.4" 1280x800
I decided to try if 4200 rpm wasn't fast enough for my needs, since I seldom work with many audio-tracks at a time. If it turs out to be too slow, I'll buy a faster external 2.5" HDD and swith the two drives around.
I found this to be the best candidate because of the nice display, and it's a very silent machine.
Happy Thomas :smile:
braincell
Post by braincell »
I'm using a standard drive in my laptop and it works fine. I'm considering an external hd for more space and will get the faster speed.
Vasfed
Post by Vasfed »
10 stereo tracks @ 44100 16 bit = 1500 kbyte/sec plus serving data, almost every modern HD has burst read/write speed above this.
Long time ago i've tested my new (at that time, p2 450 + 10 gb 5400 rpm + 64 mb ram) for maximum number of tracks,
it carryed over 100 stereo tracks (only playback, writing was a cheat - i dont have so many inputs :smile:)
Press RESET to continue...
sorry, I'm dropping in a bit late, but it only just entered my mind...
you cannot compare the performance of a 2.5 and a 3.5 disks by rotation speed alone.
the laptop disk has a much smaller platter, hence the sustained transfer rate will drop significantly.
Imho 'peak' data rates are complete nonsense - (if at all) they are measured isolated, far away from a desktop OS, or the manufacturer just reprints the transfer rate of the controller interface.
I've even seen jokes like 10 MB transfer rate - defined as 5 MB in/5 MB out :roll:
Fortunately Petal made a wise decision :smile:
braincell
Post by braincell »
I have a Toshiba Lifebook. I can do music on it alright. I love that you can make music in bed. My desktop is more powerful though.
