sync throught midi out of Pulsar II
yasuk
Post by yasuk »
Hello,
I am trying to sync my mpc 2000 with MTC or Midi Clock through MIDI out of Pulsar 2 board. What would be the best way to sync them up? i am using logic pro with SFP. No extra midi interface is available since I am in the middle of renewing system. ( I had PPC and now I am working on G4. I have to wait till I buy USB midi interface.) I would slave my mpc.
Thank you
whatever logic is happy with, midi clock or sync will work very nicely. logic can be master or slave, there is a menu for selecting mode and source...use seq midi i/o connected to pulsar midi i/o.
*edit* of course, there's a menu on the mpc as well and those settings must match the settings in logic....
<font size=-1>[ This Message was edited by: garyb on 2004-09-14 20:46 ]</font>
yasuk
Post by yasuk »
how u set up the enviroment in SFP??
Is it Possible to control another midi divice through midi through of pulsar while using MTC?
sure, although the only reason to use the thru is if you have a signal at the in that you want to go to another device without it ever going through the computer.
multiple connections can be made to the midi modules in scope.
