Working on a pretty large project recently, I started getting some of the dreaded glitches during playback.
I tweaked &/or re-tweaked everything to the best of my knowledge, but they still remained.
I then found a checkbox in Cubase - it's on the 'Advanced' dialogue of the (device setup...) dialogue that allows you to set ASIO buffer details, pick the ASIO driver etc. ("VST Multilink" I think?)
The checkbox in question is called 'lower latency'. I unchecked this and haven't had a single problem since. I also cannot detect any change in the latency of the system.
Might be worth trying if you use Cubase, have optimised your system to the best of your knowledge and still have problems.
Royston
Snap, crackle & pop? (Cubase-specific)
Counterparts
blazesboylan
blazesboylan
I tried all of the above in Nuendo (the options are basically the same under the "Devices" menu).
I then added a wordclock cuz I figured maybe ASIO was getting out of sync with my A-D / D-A converters (I use them as inserts).
No go.
I was only playing 11 tracks tonight when I tried all of this.
The only 2 approaches that work for me to get rid of crackles in Nuendo:
Incidentally my crackling problems started because:
Thanks for the tips Royston + Ricardo! Any more suggestions would of course be appreciated.
Cheers,
Johann
<font size=-1>[ This Message was edited by: blazesboylan on 2004-08-25 04:38 ]</font>
No go.
- Focus on SFP (i.e. hide Nuendo)
- Minimize Nuendo
- I jumped up to 24 bit a couple of months ago; and
- I change some setting in Nuendo in the middle of playback. As long as I don't do that at all during a session, I'm fine.
Cheers,
Johann
Counterparts
blazesboylan
