I have two PCs which I am about to link up via FXteleport, and am considering a change of routing in my setup. Currently my 1st PC has the ScopePro, UAD-1, Powercore in the same box, the 2nd PC Currently just houses the standard peripherals, video, network card.
I am considering moving the ScopePro to the 2nd PC, and putting in my Lynx card into the main PC so that way I could relieve a little stress DSP wise on the main PC and open room for possibly another 2nd UAD-1.
From just a few minutes of random though, I am guessing I could just connect the two via lightpipe? I can get 16 Channels from the Lynx card and 16 from the ScopePro I belive.
So Im thinking I would just take some lightpipe cables and directly connect the two cards and set up SFP to have a block of 32 adat channels instead of the standard Asio2 LFT module as the inputs, is that currect?
But what I am curious of is do I just use ADAT out to get the sound back into the main PC with the lynx card? or is there a simpler method, also if I send 16 channels of adat back to the lynx in my host, Nuendo 2, what would be the easiest method to mixing down. The Lynx card has a routing mixer similar in the manner of the RME, I can choose a virtual 16 channels of routing.
Just confused on how to get all that sound back into the main PC and make it so I can have all the control I do when using the scope card as the master device.
Ide like to the use the lynx card since it has very good converters and a great clock to sync the Scope card to.
Any thoughts? I am at the very early stages of thought on this so am trying to get all my stuff worked out before I start tearing things down.
To summarise, I wanna try and still use SFP to mix everything via routings to the STM mixer, but I want to use my Lynx card as my master sound card and PC, ASIO outputs/inputs and then use SFP to as a loop and use effects/synths etc etc.
Is there an easier way to do this other than the adat? what about spdif and aes3/ebu, one thing that concerns me about using the adat is that then I would have no option for additional I/O, there must be a better solution
Thanks for and help on this gang,
Cheers!
