modular freq to midi!
bosone
Post by bosone »
probably it was already asked in the past...
a modular module to convert frequency generated from sequencers and so on to midi notes. the inverse of MVC, to be more clear... i enter with freq, velocity, gate (on/off) and it generates midi event...
absolutely a must, since modular is becoming really complex, but it has still no out interface with the external midi devices
Plato
Post by Plato »
Not exactly what you're asking for, but have you checked this out ?
https://forums.scopeusers.com/viewtopic.php?f=15&t=11480&0
Maybe it could be adapted to suit ?
Shayne White
Post by Shayne White »
I'd like a CV-to-MIDI signal converter within Modular. If I set a random-signal LFO to output CC# 74, for example, I could use it to control Minimax. I don't know of anything that does that! It'd be like Reason.
Melodious Synth Radio
http://www.binary-sea.com
the problem is the generation of the 'note' midi event. You can modify incoming notes, but not make them 'on the fly' - there's alot to be improved in this domain.
@Shayne
a display with assignable midi controller does what you want.
The best is the
free display module from Flexor, but even a meter on a mixer does the trick (if it accepts CC assignments - some do) or the VU of modular, though it makes not much sense to assign a CC to a virtual LED, but it does work :wink:
setup proc:
connect be the LFO output (or whatever calculates the function) to the input of the ValueDisplayPlus module. Then assign a CC# to the slider of the module.
Connect midi out of Modular to midi in of Minimax.
Assign the same CC# to the desired control
This is kind of a cludge and should be improved for shure...
Shayne White
AWESOME!!!! I'm going to have great fun with it, I'm sure!!
Shayne
There's some intesting posts by alfonso in modular patches forum, more fun to be had:
https://forums.scopeusers.com/viewtopic.php?f=15&t=10192&6
(who asked for 64 step seq's? https://forums.scopeusers.com/viewtopic.php?f=15&t=10866&5 )
https://forums.scopeusers.com/viewtopic.php?f=15&t=8161&2
https://forums.scopeusers.com/viewtopic.php?f=15&t=6290&5
https://forums.scopeusers.com/viewtopic.php?f=15&t=2616&3
https://forums.scopeusers.com/viewtopic.php?f=15&t=8628&0
Where have you guys been all the time? :grin:
Also, Michu gave me some great idea's on how to do freq2note. So we can use keyfollow on filters in modular without MVC, for example... Gonna try them out one of these, check the appropriate fora :smile:
alfonso
Post by alfonso »
Re: modular freq to midi!
links fixed in all associated topics, please verify.
Joey
Post by Joey »
All links are working, thank you very much.
Berny Shoes
Post by Berny Shoes »
Thanks for restoring all these links Valis
np, i owe you guys more...
