S/PDIF in fixed in SFP 4
Planet Z Announcements
braincell
Post by braincell »
For a long time my S/PDIF input wasn't working either on my Pulsar or Luna (although the outs worked), and I gave up on it a long time ago. I just tried it using SFP 4 and it's working again. Thanks CW for finally fixing this.
<font size=-1>[ This Message was edited by: braincell on 2004-07-25 04:07 ]</font>
Eon
Post by Eon »
hello,
my SPDIF also doesnt work, just input but I have SFP 3.1a, I didnt try output.
The weird thing is that on the same system and before half year when I used SPDIF, it works but now I have ticks, ticks for every second
Did you have same experience or?
Music, Me and Myself
<font size=-1>[ This Message was edited by: Eon on 2004-07-25 04:18 ]</font>
<font size=-1>[ This Message was edited by: Eon on 2004-07-25 04:19 ]</font>
worked for me in v3 and v2(and maybe v1 too, i just don't remember), but i'm glad you have it going now...
blazesboylan
Post by blazesboylan »
Always worked for me too, going back to version 2.
Eon, have you got master + slave set properly on both devices? Maybe try swapping them so that whichever device is currently master becomes slave, and vice-versa?
Eon
Post by Eon »
Everything is set properly, just Spdif is not working, anything else is like swiss watch named pulsar :smile:
braincell
Post by braincell »
Mine worked with version 1 but not 2 and 3 and works again with 4.
samplaire
Post by samplaire »
Have to try this!
interloper
Post by interloper »
The question is, does your SPDIF work on the same card for both Input & Output?
The only way I got mine to work was to use the SPDIF Out on my Pulsar II Plus and the SPDIF In on my regular Pulsar II.
I could not get it to work on the same card at 44.1 kHz. 32kHz did work on the same card.
Eon
Post by Eon »
sorry for missunderstanading but I have only one card :smile:
Output is working but input has clicks on 48Khz
braincell
Post by braincell »
Mine worked the same way on both cards with the input not working on both before and everything working after version 4.0.
samplaire
Post by samplaire »
Looks like mine doesn't work :sad: My Luna works great on the SPDIF output while the input doesn't work (strange). Probably it's broken? But why does it work one direction and the other not... ok, nevermind... Just have to repair it somewhere.
ebrjvd
Post by ebrjvd »
Optical S/PDIF only works on the ADAT A ports, not on B.
To avoid click, you must select "Slave" on the "Samplerate Settings" menu.
Jos
samplaire
Post by samplaire »
Luna has got only the electric port. no optical.
