Handy tools for troubleshooting
darkrezin
Post by darkrezin »
A couple of handy utils for troubleshooting click/pop problems with Windows DAWs:
http://www.mark-knutson.com/technique_to_target_inc/
I originally found out about the app here:
http://sound-on-sound2.infopop.net/2/Op ... =150108472
<font size=-1>[ This Message was edited by: dArKr3zIn on 2004-07-12 14:04 ]</font>
BingoTheClowno
Post by BingoTheClowno »
Great! Awesome! :smile:
<font size=-1>[ This Message was edited by: BingoTheClowno on 2004-07-12 16:07 ]</font>
BingoTheClowno
What I am wondering is, where these settings are stored: the registry or the BIOS? My mobo's BIOS has only one global PCI Latency setting.
darkrezin
Post by darkrezin »
Sorry, I have no idea! I haven't tried the app yet (I don't have click/pop problems) but I have seen others have good results with it. I may give it a try sometime to see if it results in a performance boost, but I just don't have time at the moment :/
BingoTheClowno
Well there are two applications, one runs a global test on your PC and you have to kinda figure out where the performance bottlenecks are. The second application, I like its name Ulysses :smile: , allows you to look at the PCI Latency settings on all devices that use one and modify those settings accordingly.
darkrezin
Post by darkrezin »
I've finally gotten around to testing these tools, and I have to say they do a damn good job. I have an Asus P4PE-based system which I was just using for internet and misc duties. I recently decided to use it for 2 of my Pulsar cards - to my dismay I was getting PCI overloads in SFP while using the firewire and wireless internet. I ran the tool and set all other PCI devices to PCI Latency 96 - the same as the Pulsars. No more PCI overloads! The author does a version for $10 which sets the values on every bootup. I really recommend it!
[edit] I should add that I also set the graphics card to PCI Latency 96 (it was 256 before!).
On a sidenote - I discovered that Pulsar and Pulsar2 have different PCI Latency values - Pulsar has 128, while Pulsar2 has 96. Slightly odd I thought.. however the system is working fine so no real worries.
<font size=-1>[ This Message was edited by: dArKr3zIn on 2004-10-31 19:09 ]</font>
Music Manic
Post by Music Manic »
Which latency ettings do yo
u use?
darkrezin
Post by darkrezin »
I set everything which had higher PCI latency value to the same or less than the Pulsar2 - wireless 64, AGP 96, Gigabit ethernet 96, etc. I'm sure I'll be tinkering with it as I start using my system a bit more.. I'll try and remember to report back any further findings.
Music Manic
Grok
Post by Grok »
Great!...Thanks dArKr3zIn
<font size=-1>[ This Message was edited by: Grok on 2004-11-05 21:11 ]</font>
krizrox
Post by krizrox »
luigicampala
Post by luigicampala »
this is a great tool for testing your configurations latency
http://www.thesycon.de/deu/latency_check.shtml
you might want to check it with a low level scope project.
for comparison:
i have an absolute max of 28µs
luigicampala
ok,ok...
when moving a window it´s 29µ :D
but it depends on what scope-project your running
Mary Mungo
Re: Handy tools for troubleshooting
Post by Mary Mungo »
The link for mark-knutson pci pop and click eliminator has been moved and renamed as Doubledawg and Ulyses
the location is found here
http://www.mark-knutson.com/t3/_index.html
:D There Ya' Go. I might need it in a couple weeks.
That DAWg will definately hunt. :wink:
Ankyu.
