Waves V5 is out!
Planet Z Announcements
Waves 5 is out (at least according to the Waves website) and FREE for current users.
  • What's New in V5:
    Tempo Sync - Four plug-ins have been upgraded with a new feature of automatic tempo sync. The plug-ins are: Enigma, MetaFlanger, MondoMod and SuperTap.
    The new functionality enables those plug-ins to lock to the host application’s tempo and tie the relevant controls to that externally controlled tempo.
    Morphoder MIDI Control - Morphoder, part of the Transform bundle, now becomes a true virtual instrument. In all supported host applications you will be able to assign a MIDI track output to an open instance of the Morphoder and play its internal carrier from a MIDI track using recorded MIDI data or live playback from a MIDI controller.
    Waves 360° Bundle for Windows - The Waves 360° Surround Tools Bundle is now available for ProTools TDM running on Windows.
    Waves 360° Bundle – Native - On both Mac & PC, the Waves 360° Bundle now supports Native processing, running as RTAS & HTDM.
    HTDM Support - All Waves plug-ins now support Digidesign’s HTDM architecture, enabling Native processing while maintaining important TDM functionalities such as changing a track’s number of outputs (mono ->stereo, mono/stereo ->surround), inserting a plug-in on Aux and/or Master tracks and more.
    Note! – ProTools TDM 6.4cs4 update is required for HTDM support http://www.digidesign.com/download/cs/
    HD Accel Support for Windows - Digidesign’s new HD Accel hardware is now supported for Windows.
    96kHz Support On HD Accel - Several plug-ins are now supported at 96kHz sample rate on Digidesign’s new HD Accel DSP cards.
    The enhanced plug-ins are: C4, SuperTap*, Morphoder, LinMB, LinEQ (Broadband Mono component only). * SuperTap is now also supported up to 192khz in Native process.
    Digi 002 and Command/8 Control Surface support - All Waves plug-ins are now officially mapped to Digidesign’s Digi 002 and Command|8 control surfaces.
    Automatic Delay Compensation support for Pro Tools - All Waves plug-ins are adapted to support the new Automatic Delay Compensation feature in ProTools 6.4
    http://www.waves.com/
<font size=-1>[ This Message was edited by: valis on 2004-07-08 14:13 ]</font>
