Removing sub frequencies ("steep" filter?)
Counterparts
I've been trying to remove the low frequencies (i.e. below 30-50 hz roughly) from various tracks / instruments in a mix I'm working on, but without effecting the tonal balance upwards of 100-120 hz but find that it's difficult to do this.
Even using a 48db/Oct filter, if you want to chop out the really low stuff, you're also eating into more useful frequencies.
I've been trying to use a high-pass filter for this purpose...perhaps a low-shelf filter is more suitable? Or...is there a 'brick-wall' type of filter (96db/Oct?) which would do the job?
I'm interested in any ideas regarding precise EQ-ing in this low frequency area.
Royston
Royston
Plato
Counterparts
Micha
- alfonso
Obviously it is...near higher frequencies sound totally different if those you want to remove are there or not...On 2004-07-01 06:15, Counterparts wrote:
Royston
There is a setting on Sound Forge "paragraphic equalizer" (if I remember well) that was the removal of everything in the file below 20hz. Well, the result of this was a considerable boost of the low end perception...
The psycological interpretation of sound is someting tricky....your brain can create unexistent frequencies by the perception of some harmonics that naturally are present only together with those frequencies you "create from nothing"...
blazesboylan
Royston there is a 1/3 octave EQ plugin. I don't remember how low it goes frequency-wise though, and CreamWare seems to have dropped it from the shop.
A multi-band compressor is another option. Maybe this is what Ricardo was suggesting? Optimaster (and Finaliza?) has a crossover + limiter. Compress the hell out of the signal below 50 Hz.
You can't get much reduction from the shelf filters (-12dB I think?), so I wouldn't bother with them for this task.
There's also the notch filter.
And even the peak filter would probably be narrow enough, at such low frequencies, to reduce the 30-50 without affecting other frequencies too heavily.
And finally, there's the wacky approach. Take a compressor and feed the signal into it. Mult the signal out into a low shelf filter. The output of the filter should have nothing above 50 Hz. Feed the filter into the side chain of the compressor.
The output of the compressor will give you a pumping action which could sound horrible. But if the ultra-low bass is rhythmic it might just work. Not what you asked for, but still...
Cheers,
Johann
Cheers,
Johann
Plato
Here's Early First 24db/octave eq....might help (and it's free - whoopee!)
http://www.planetz.com/forums/viewtopic ... forum=16&0
- astroman
Counterparts
- dbmac
Micha - I can't find a Frequency Space Editor in Audition 1.5. There's a Fequency Band Splitter, FFT Filter, Notch Filter - these don't seem to be the tool you describe. Is "Frequency Space Editor" the actual name? Is it in the filters section? It sounds interesting, I'd like to try it out.On 2004-07-01 11:51, Micha wrote:
In Audition 1.5 is a function called Frequency Space Editor. Inside it you can mark the desired frequencies(!) and mute them. Maybe you check it out with the now available trial version?
Thanks,
/dave
sonolive
i have developped a 60 db/oct into a mixer ...
http://www.planetz.com/forums/viewtopic ... orum=16&32
you should try it ! and tell me if it does the job !
if not i can try to dev a 96 db/oct !!! but at these slope values, dephasage (i hope it's the good english term !) is very important !!! you have to be carrefull with these kids of filters !
- Mr Arkadin
BTW there was a big discussion here about this subject, in case you missed it, which may offer up a few more suggestions.
Me? i cut frequencies of instruments as i go. Pad sounds i almost automatically just chuck in the standard CW low cut (from the effects section, not the inbuilt mixer one - dunno if the quality is any different).
Quite often cut voices too, guitars, basses, just about anything to stop that bottom end clogging up. Also i do any freq cuts before i compress. i usually start the cut at 80Hz and then move it around for each source.
The GraphEQ is also good for notching out indivdual low frequncies (it's not in the shop anymore - is it now part of he Effects Package?)
Mr A
<font size=-1>[ This Message was edited by: Mr Arkadin on 2004-07-04 08:24 ]</font>
Mr A
- astroman
Since I have no idea about the mathematical principles of that stuffOn 2004-07-04 06:25, sonolive wrote:
They discuss alias filters in the high frquency range, but the application quested in this thread looks rather similiar, except the different frequency range.
[snip]
... An aliasing filter creates a pre/post ringing. As a result of this ringing the A/D and D/A converter has a delay (a little less than1 ms at 48 kS/s with a 0.45/0.55
filter). The ringing is a result of the mathematical equations whereby the filter is constructed and is as it is unavoidable, if the filter is used to minimize aliasing.
Generally a steep filter has more ringing than a less steep filter.
[snip]
is this a general charecteristic of any filter or are some 'brands' more sensitive than others ?
The frequent request of equalizers with low Q values seems to point in this direction.
Or is this only of relevance if a physical conversion process takes place ?
<font size=-1>[ This Message was edited by: astroman on 2004-07-04 18:42 ]</font>
sonolive
hi astroman ...
the phase rotation for filtering is not only a problem of ADDA conversion ...
even in analog, any filter products a phase transformation .
it's a mathemetical law ... and the "best" the quality of the filter is (factor Q) the bigger this phase rotation is !
they are mathemetical law about "Les systemes oscillatoires" (in french that may be oscilllatories systems ??? (in english !)
in analog, globaly, the best the electronics componant an the circuit design are, the less this rotation is ...
in digital , there are other things to consider but, this phse transformation takes place too ...
my english is very poor and i hope it's clear, peharps someone could explain it better than me !
Counterparts
Thanks Mr A - I had found that and was actually going to post a link to it until I spotted your post!Mr Arkadin wrote:
My most often used effect!Me? i cut frequencies of instruments as i go. Pad sounds i almost automatically just chuck in the standard CW low cut
I haven't tried that yet, but intend to give it a go!The GraphEQ is also good for notching out indivdual low frequncies
Another possibility is to chain some filters in series in modular - worth a go I think, if only to find out how much 'ringing' is introduced around the cut-off frequency.
(Thx again to everyone for their postings)
Royston
decimator
If you have Spektral Delay : the 2 first bands are 0 - 43 Hz and 43 - 86 Hz.
You can really terminate frequencies !
Not to a Hz precision but ...
For sharp bandpass a must ( among other things of course )
What I would like to know is the behaviour of a monitor near its low range : for instance I notice at time for some sounds quite nice rumble effects like a T-Rex jogging ...
Is it in the sound and / or artefacts ?
Micha
dbmac: Switch to Spectral View.(F9) Set 1024 in Options/Settings/Display for better sight. With right click and mouse wheel you can zoom in. Select the Marquee Selection tool from the toolbar. You now can select any area(!!) inside the view. Best trick is to select a noise and use Fill single click from the DeClick filter. It replaces by using frequencies from the surrounding area. Very good.
