RingMontylator
Guest
This file has expired and is no longer available here. The owner of the topic can re-upload the file, or post a link to an off-site file. <BR><BR>_____________________________________<BR><BR> this patch make a crossmodulation, but only when you send a note to the midi in...and the crossmodulationfrequency is in the pitch of the midi-in-note! so you can make "musicaly" crossmodulation "play lines" with the modulation...why not a argeggio with the notes of the same accord to the crossmodulationfrequency? or the rootkey of your accord? whats about "pitched drum-sounds"? if you make a really short decay to the crossmodulation, you can add "clicks" to your note, or ....
