Once again the time has come to upgrade.
I am thinking of the following set-up:
MSI K7N2 DELTA-L NFORCE2
AMD ATHLONXP BARTON 2600+
512 MEGS KINGSTON KVR400X64C3
Does anyone know of any compatibility issues with any of the above? Should I stay with Intel boards?
HAS ANYONE BOUGHT ONE OF THESE SO-CALLED QUIET CASES? are they quieter enough to justify the expense?
upgrade time
petal
maakbow
whatever you do get that has quiet [or no] fans, you still have to deal with HDD noise and monitor noise ...so build a big fat timber box for you puter and get a LCD.
a 18mm MDF box internally damped with clever air path will do more to reduce noise than most comercial quiet cases i,ve seen ...unless you have the $$$ for this...
http://www.zalmanusa.com/usa/product/vi ... 4&code=020
Maak
Maak
