dear alfonso... another MIDI device request!!
bosone
Post by bosone »
just another little midi device, to let you test the potentiality of SDK :grin:
you input a midi CC with range 0-127 (normal controller behaviour), and at the output the range is limited between a minimum and a maximum (ex: 34-98).
marcuspocus
Post by marcuspocus »
This doesn't already exist on all controler in the Controler assing window?
i seem to remember so... I'll check tonigh
If not, well, :grin: it's needed! :grin:
bosone
Post by bosone »
yes, there is a "modulation" control in the CC window assignment, but i never figured out how to let it work in the way I want!!
a dedicated device could provide more precise settings (ex if you want to live control the delay wet signal between a min and a max or a channel volume)
j9k made a module for that. I think it's called something with BMT / Better Midi Control.
bosone
Post by bosone »
i cannot find the j9k module...
j9k
Post by j9k »
bosone
Post by bosone »
this is not the device i had in mind... to complicated!
i just meant a little "box" with midi in, midi out, two knob (min and max value) and something to choose a CC number!
