Midi Transformer 1
alfonso
Post by alfonso »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: MIDI Tool<BR> _____________________________________<BR><BR> This is another thing I desired for long time.
You can select alternatively incoming CC's, Velocity data or Pitch Bend, on any or multiple channels, and output any CC of your choice from 0 to 127, on a Midi channel you want.
I find very cool to assign whatever CC to pitch bend controller.....
I hope the device works well, It should be a sort of beta, but is not that complicate thing....
Enjoy :smile:
<font size=-1>[ This Message was edited by: alfonso on 2004-06-03 02:58 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... former.gif" BORDER="0">
marcuspocus
Post by marcuspocus »
cooooOOl !
Top! That a big step up in midi handling in sfp ! :smile:
You can now use mackie control (or alike) to control sfp devices!!!!
Yep, faders and rotary encoders sends pitch bend (amongst other stuff) on the mackie control :smile:
Just an example...
Maybe that the starting of a real mackie support? :wink:
Anyway, thanks alot Alfonso!
That the free sdk your beta testing?
alfonso
Post by alfonso »
Right...and as you can imagine I can't talk about it, but I can publish devices... :smile:
borg
Post by borg »
veryyy nice, and very promissing.
knowing that i once did the dishes with this man while he was in his undies and socks... that makes me happy! :lol:
i'm grateful for what all developers have done so far: super synths/fx for low prices, excellent freebies, advice,... but this could be a new era: lots of small useful things most commercial
developers don't have time for, awesome synths from big time mod freaks...
well, let us not get too excited :wink: time will tell.
andy
the lunatics are in the hall
rodos1979
Post by rodos1979 »
Very useful device indeed! :smile:
Great! Thank you! :smile:
scary808
Post by scary808 »
Man!!! I ended up selling my VS880.
Now I wish I hadn't.
Keep up the good work!
http://www.planetz.com/forums/viewtopic ... forum=30&7
yhanks Alfonso!
bosone
Post by bosone »
thank you VERY much!!!
Jngaelin
Post by Jngaelin »
Thank you Alfonso !!! :grin:
JLS
Post by JLS »
very good :smile:)
Little tip new device
1 controler input and x (3-4) controler output
( cc x input - cc x filter,cc x resonance, cc x other mod target ....... ) negative and positive polarity
:smile:
<font size=-1>[ This Message was edited by: megerov on 2004-06-03 10:41 ]</font>
great idea!!
rodos1979
Post by rodos1979 »
I d like to see a variation of this device where you could specify which controller becomes which.
For example
cc1 -> cc64
cc7 -> cc2 etc
Immanuel
Post by Immanuel »
I do not fully understand it yet. I will experiment. Thank you.
alfonso
Post by alfonso »
Ok...going from left to right:
you choose a midi channel, or some of them, or all, FROM wich the controller/s is/are coming, then you chose alternatively if it's a CC, no matter the number, or pitch bend or velocity data that must be transformed, then on the right you decide wich CC# will be output instead of the incoming data, and on wich midi channel it goes out...
I still have to figure how to select the CC# of the incoming data that will be transformed, in the case of CC transformation, but I swear that as I know it I'll do it! :smile:
For now many tasks can be also be made by loading several of them, as the module itself is absolutely light, almost unexistent in dsp consumption, and it's size in the routing window is really small...a bit the live bar can be filled too much, but I hope to find the way to make a more flexible device...
For now I'm happy to have something that is a bit of a revolution in my workflow and I'm having very good time in using pitch bend, that acts in a sort of bipolar way controlling other things, and link other modulations to the velocity values....
Immanuel
Post by Immanuel »
Thank you for the explanation. I understand it now.
finally there's hope for Scope midi - now that Alfonso takes care of it :wink:
great start, Tom :grin:
borg
Post by borg »
again, many thanks alphonso! very handy devices.
however, would it be easy to rename the devices, or at least change the name at which the device will pop up in the routing window. i thought i could do it myself by changing the file name, but alas...
it's nice to see your mixer become much smaller if you rename it (possible when opening the surface)...
a chacha or a mitra in my projects would look cooler, and would take less screen realestate. :smile:
andy
lovenara
Post by lovenara »
hi
i wonder how to load it and connecting it to which object?
thn
djmicron
Post by djmicron »
if you need to use it with the stm mixer,
connect the midi in of the transformer to the midi source and the midi out of the transformer to the stm midi in, if you need to convert more than one midi channel and controller, you'll need some midi merger and more instances of the transformer.
If you need to convert more than one cc on the same midi channel, i think this is not the best device to use, but this is good to convert midi channel.
<font size=-1>[ This Message was edited by: djmicron on 2006-03-16 03:04 ]</font>
Peter Cherry
Post by Peter Cherry »
Hi Alfonso,
I am traying to find any MIDI filter, because I need to unfilter this CC B0 7B 00 Ctrl Chg cc:123 v:000 from my input only.
I tried you device, but unfortunately it could not be used for this purpose. What about any MIDI filter or is it possible to modificate your device little bit for this purpose ??? Sorry I am not programmer :sad:((
Thanx
Petr
