pc crashes when using dsps not when just running as sound ca
danrollaj
Post by danrollaj »
please help my card has never worked properly (pulsar 2)
system p4 3.06gb 800fsb gigabyte main 1g ram
the card works ok when i open vst2.5 into the scope system but when i open a synth or sampler at no set time the system locks my whole machine repeating the notes it stuck on untill reboot of the pc.ps i run vst into the scope mixer through sterio outs not each channel on its own fader....creamware has never replied ever to my headache and the short goes that the card has let me have has got me hooked
What is vst2.5? What is your main sequencer/application?
Are you using XTC mode or are you running SFP.exe?
Have you read over all the posts pertaining to HT (hypertransport), ACPI and IRQ sharing?
What is your motherboard make&model and what pci cards do you have? What slot is the Pulsar2 in? what is your graphics card?
in short we need more info I think. also try reading through some other posts around here...
...or stay stupid and buy a mac (G4), like I did :grin:
recommended :smile:
wolf
Post by wolf »
sounds like a Midi loop .. check your connections, soft- & hardware. Or better disconnect all Midi and reconnect one by one until the repeating notes appear.
best
Wolfgang
