Cubase system link
Mat@Audio_Fiction
Post by Mat@Audio_Fiction »
Hi there!
Has someone been successful with pulsar system and VST system link???
(3 pulsar in one PIV 2.8 ) linked with a RME...
I tried last week :sad:
I used spdif connections...tried with master and slave...
Everything seemed to be ok as read in the manual...but no way!!!
please help...
Anyone succeeded?
<font size=-1>[ This Message was edited by: Mat@Audio_Fiction on 2004-05-28 08:32 ]</font>
<font size=-1>[ This Message was edited by: Mat@Audio_Fiction on 2004-05-28 08:33 ]</font>
angel777
Post by angel777 »
..had the same problem...
I you must use adat for vst system link..
If your rme is set to slave get the clock from adat and get and send the VSL from there!
Maybe if the clock is received from adat the spdif port is not on synch.
Good luck!
virtualstudio
Post by virtualstudio »
hi
As I'm not so long back in buisness again, I didn't have time to try System Link yet, but I remember you set in the samplerate window to SP/dif and then you have optical sp/dif
through your Scope Adat port, thats how I used it before with my DAT recorder with optical sp/dif
let me know I really would like to use this to.
