I have been using creamware products for about 2 years on a mac and recently moved the card into a pc to run with vstack. My problem is that when using vstack the latency on the XTC instruments is so bad that it is unusable, but there is no latency problem when i use the native VST instruments. i have frigged around with all of the settings and am running the card (pulsar 2 - SFP 4) at is highest possible samplerate but nothing makes any difference!!
Any Ideas???
sam
V-STACK AND XTC LATENCY PROBLEMS
Try to open CTRL panel of ASIO when you are in V-Stack, then change on fly the latency of your CW Card (up or down) and then reset at your old latency.
In my system the latency delay disappear...
I hope that will resolve your problem
<font size=-1>[ This Message was edited by: erminardi on 2004-05-21 08:30 ]</font>
Hi
Have you checked out Gonzoft's tips....
http://www.planetz.com/forums/viewtopic ... forum=3&15
The ASIO panel does not appear to work in XTC mode, you must edit the Cset.ini file.
Regards
Kenf
Regards
Kenf
marcuspocus
Yeah right, cset.ini indeed
But also don't forget that V-Stack doesn't do any latency compensation...
Hey btw guys! Would you like a SFP for XTC, or kinda?
Have a try at the demo of this small host, you'll find the interface as some similarities with sfp
http://www.console.jp
I bought it last week, and having a blast with it
marcuspocus
