Ever since I got the Vectron I was looking for a cheap X-Y MIDI controller. I asked the same question in NI's Reaktor forum with some good replies (see this: http://www.thinkmig.com/stcspecs.html ). I was wondering what are you guys using to control your Vectron?
At the moment I am using a Peavey 1600x controller where I assigned two of the sliders to control X and Y which is not the best way to do it but it works.
PS
The keyword is cheap!
<font size=-1>[ This Message was edited by: BingoTheClowno on 2004-05-12 11:56 ]</font>
Vectron X-Y controller. Any suggestions?
- BingoTheClowno
gedas
- BingoTheClowno
Kymeia
Could you use something like a Wacom artpad? - I have one and am planning to try it on Vectron and other synths with XY controllers when I get my new DAW (soon).
You can pick up a Wacom Graphire for under $50 and there are other makes that I believe are even cheaper.
The other alternative I was thinking of would be a standalone touchpad (like on a Laptop) - or you can get touchpad-keyboards pretty cheap.
eg
http://www.keyboardco.com/tns/touchpads.htm
<font size=-1>[ This Message was edited by: Kymeia on 2004-05-12 17:53 ]</font>
eg
- valis
I've seen a few webpages over the last couple of years on how to convert a standard pc gaming joystick into a midi X/Y device. If you intend to connect it directly to the Pulsar's midi input then you'll probably need to google for the variety that uses an external circuit board that connects via the game port on one and and midi on the other. A cheap & effective solution imo.
samplaire
I found the cheapest way to do it. I have a Logitech gamepad featuring an analog x/y controller (or it can be any joystick) and I found a free mac joystick-to-midi conversion application and it does the job very well. There should be at least one PC counterpart for this, I suppose.
[edit]
here you go:
PC
1. http://www.harmony-central.com/Software ... dijoy.html
2. http://krypt.dyndns.org:81/joy2midi/
3. http://www.vellocet.com/software/VMIDIJoY.html
MAC
1. http://www.steim.nl/Software/midijoy.sit
2. http://www.steim.nl/Software/JunXion.dmg - this is shareware for OSX
<font size=-1>[ This Message was edited by: samplaire on 2004-05-13 07:03 ]</font>
[edit]
here you go:
PC
MAC
calippo
samplaire
But remember it will work great but only with an analog gamepad - it's because the arrows on a plain gamepad have only 2 states - 1 or 0 while the analog ones have a range of numbers. something like this
- valis
Here's a pretty interesting PC based app for doing the conversion and a lot more:
<font size=-1>[ This Message was edited by: valis on 2004-05-13 08:37 ]</font>
A completely free application for use in commercial and non-commercial music projects and studios, converter is a very powerful and flexible real-time application providing an advanced midi input processor, clock sync'ed lfo to midi generators, filter bank -based audio to midi converter, gameport or joystick to midi converter, and mouse or touchpad to midi converter in an all-in-one solution.
http://www.urr.ca/software/software.htm
- BingoTheClowno
Sir
