Hi all
my setup: pulsar/nuendo using XTC.
Is it possible to split a recording signal in nuendo? I want to record vocals/guitars in nuendo. The recorded file should be a dry signal, whilst the monitoring signal should be wet using fx/verb so the musician hears the wet signal.
This is what I do now:
When I want to record a signal I create a new audio track,
select an audio input port (one of the z-link ports I defined in the input/output settings window of nuendo)
and press the recording enable swich on the track itself and start recording.
Simple. Or not? In the neundo mixer window I can see the input ports and the signal coming in, I can even use inserts on these input ports, but I somehow don't hear these inserts back on my monitoring system, and even worse, I think I then record a wet signal (but I haven't tried this, now it comes to my mind). So is it possible to split a recording signal in nuendo into a wet monitoring signal and a dry signal for recording?
regards Wilbert
nuendo/XTC::: dry/wet recording setup
wilbertenserink
Hi!
In cubase you just have to create audio track assign some effects and put monitoring on that channel on. Don't pres write button! You then should have dry signal recorded and than you can just change settings of effects. Don't use direct monitoring for monitoring with effects, because it will bypass effects.
Hope I'm not wrong in any way. Please someone correct me if I've sad anything wrong!
I hope this helps you in any way!
Sorry for my bad english.
Best regards, Igor Benko
<font size=-1>[ This Message was edited by: ibenko on 2004-05-06 19:00 ]</font>
wilbertenserink
