a correct monophonic signal from a P. with 6 voices setting
erminardi
Post by erminardi »
Hi, does anyone knows how to get a correct monophonic signal from a modular patch that have, for example, 6 voices setting?
My problem is that after the first key pressed I cannot hear nothing before the relase of that key.
I wish create a patch that reproduce my synth CRUMAR DS-2: he has 2 osc + 1 noise MONOPHONIC plus a switchable layered POLYPHONIC (6 voice) pulse oscillator.
I wish create one modular patch that have both monophonic channel-strip and a poliphonic channel-stip inside... does anyone know if this It possible?
I think It's a problem of envelopes rettriggering...
Thanks at all :wink:
ps. sorry for my bad english...
how about distributing the patch over 2 instances of the Modular ? One mono, one poly (an empty modular is a close to nothing load)
welcome btw :smile:
erminardi
Post by erminardi »
Ok, thanks for the reply, but I need a single instance while I will use it as XTC mode in Cubase.
Now I have 2 instances mixed at output, but lfo, filter and internal mixes are double...
do you think that's not possible one mono/poly instance?
Look at my attachments, for example.
[img]http://www.cactustudio.com/creamware/cr ... em.jpg[img]
[url]http://www.cactustudio.com/creamware/cr ... 04.dev[url]
[url]http://www.cactustudio.com/creamware/cr ... ow.dev[url]
If you right-click modules, you can make them monophonic. It's an override on the patches' poly setting.
hi erminardi,
my answer was more of a 'lazy man's approach' than a proper solution of the problem :wink:
nevertheless I found it handy frequently to use several instances because that way the same midi cc can be assigned multiple times.
That way one instance controls the other, or it can be used as a morphing controller.
at0mic's hint is probably more in your direction. The colour of the modules reflects the mode change from mono to poly - took me a couple of years to notice :roll:
ps: you can edit your posts :wink:
:lol: same second...
<font size=-1>[ This Message was edited by: astroman on 2004-05-02 17:53 ]</font>
erminardi
Post by erminardi »
On 2004-05-02 14:43, at0mic wrote:
If you right-click modules...
Yes, but after the first key pressed on my keyboard I cannot hear nothing before the relase of that key when I set mono-modules in a poly patch.
erminardi
Post by erminardi »
