b-2003
virtualstudio
Post by virtualstudio »
Ive got the B-2003 now
wow what a sound!
the only thing when a change a preset the midi channel gets changed too. is this normal or a bug?
regards
I assume it's related to the distribution of organ manuals to keyboard ranges.
Mr Arkadin
Post by Mr Arkadin »
Unlike all other devices, B-2003 saves the MIDI channel with the preset. i bugged CW about this when it first came out and they sort of just said 'that's how it is'. If you want to use a different MIDI channel you'll have to open each preset, change MIDI channel, then resave each preset individually. Annoying, no?
i have some presets available here at planet z. They include all the original presets so you can replace the file in the Presets folder (move the old one to somewhere safe though just in case!).
My presets also come in two flavours - original MIDI assignments and also a file with a keyboard split using MIDI Ch=1 (Pedals still on MIDI Ch=3).
i open a Seq Source module and dedicate it to just B-2003 so that i can use MIDI Chs 1-3.
Mr A
