Hi all,
Well in a few days I should have the rest of the parts for my new PC I am building, I think with all the hoopla going on right now ill let the heat dye down a little before I switch to 4.0. What I am wondering is, if I am performing a fresh instal for everything including the OS, what drivers will I be using, the way I installed my card the 1st go round was, when Windows found the card I selected my own drivers and after the card was installed withg drivers then installed 3.1c
So if there is no new drivers for 4.0 as I am guessibg, do I use the old 3.1c drivers 1st and then install 4.0 directly from there?
Cheers!
On a clean install, 3.1c drivers for Scope 4.0?
sinix
Basic Pitch
Micha
Drivers are the same. I did a setup in a new folder, a copy of all other plug-ins, edit scope.rgy, copy+paste the other keys and finally deleted old folder. Checked with a test project (Cooledit->SFP packed with mastering goodies->WaveLab Lite) and then deleted old folder.
IMHO it's best to install the drivers first, as usual. See Tips&Tricks forum for more information why. (1. drivers,2. audioapps and/or sequencer, THEN SFP)
