Intel D875PBZ, P4P800 deluxe, or P4C800 Deluxe E, what board
Hello,
I own all 3 cards, but do not have the time to test everything atm....
I want to put 1x Scope, 2 x UAD-1's, and a TC PowerCore FIREWIRE in it.
I have P4 2.8E and a P4 3G (Northwood), and I am not sure what to choose....
Any recommendations? Anyone here tested such a setup?
Maybe with Motu 828mkII as well?
Regards,
jea
Regards,
jea
Hi there,
I have A ScopePro (15) DSP, a TC Powercore PCI & a UAD-1, I have them all in a Athlon system right now, but I am planning to purchase a D875PBZ this week, here is a post from Sinix that may be of help
http://www.planetz.com/forums/viewtopic ... forum=19&0
Cheers!
Cheers!
- ChrisWerner
I have to agree with Basic Pitch.
I have the same Mobo, it´s absolutly smooth and stabil.
EDIT:
I feel very comfortable to have an absolutly Intel system, because every program is tested with an Intel system, the rest is only compatible.
<font size=-1>[ This Message was edited by: ChrisWerner on 2004-05-24 16:27 ]</font>
EDIT:
Hi!
I have the last week tested the D875PBZ with this configuration:
Intel D875PZ in ACPI PC mode, ACPI MPC mode,
P4 3GHz 800FSB,
2 GB ram DDR400,
80 GB system disk,
2x 74GB "Raptor" disks for audio & samples,
AGP =Matrox Parhelia,
PCI1 =Firewire I/O -TC PowerCoreFW -Motu 828mkII
PCI2 =UAD-1
PCI3 =UAD-1
PCI4 =Scope Pro (15DSP) without I/O card
PCI5 =Empty
It works, but when using inserts in the mixer in Nuendo, I can only use 1. If I load more than one insert, I get noises, regardless of what channel it is on.
Except for this, the D875PBZ is great.
Is the insert problem related to Nuendo or CW?
jea
P4 3GHz 800FSB,
2 GB ram DDR400,
80 GB system disk,
PCI2 =UAD-1
PCI3 =UAD-1
PCI5 =Empty
jea
Jea,
Not sure if this is 100% correct but depending on what version Powercore FW your running (not software but firmware build), I recall on the Nuendo forums reading something very similar was a fairly wide spread issue. I belive it had something to do with early batch of Powercore FW's.
Maybe do a search or ask over there aswell.
Cheers!
PS. After re-reading your post, if it ends up not being Powercore related there is 2 other majors I would look at aswell.
1) I have read alot of nightmare stories relating to PCI firewire expansion cards, some as VERY touchy, this could be a case of the same.
2) Now this is a *MAJOR*, and thats the evil four letter word on PC "MOTU" motu us notorious for having some of the worst drivers made for the PC, just do a nuendo search on MOTU and see the flood gates open in regards to crackling audio, and poor bandwidth when using there cards.
Cheers!
<font size=-1>[ This Message was edited by: Basic Pitch on 2004-06-02 20:38 ]</font>
Cheers!
Cheers!
UPDATE:
I installed a I/O plate from one of my Pulsar II cards, and enabled the I/O's ....
Turned off the MOTU 828mkII ....
Started the PC ....
I went crazy adding plugins ....
Not a problem related to inserts anymore!!
I'm going to bed with a smile tonight!
jea
PS! Now I have to buy some A/D - D/A ....
.... and sell the MOTU's ....
Started the PC ....
jea
eh, you're right,
I am a luna(t)ech!
Happy to be able to help a fellow CW user,
I once had a 2408 MKII and it was a serious PCI problem monster so I knew that would be a likely culprit, especially on the Nuedo forums for PC guys, you can see loads of threads with similar issues.
I ditched the motu went with a Lynx and then followed up with my Scope card, all is well these days.
Glad it worked out for ya
UPDATE:
I have dissed the Motu 828mkII completely from this setup.
Scope + Pulsar II, 2x UAD-1's, TC Powercore FW.
Everything runs smooth atm.
I'm going to finish the PC soon, then I will do a realworld "stress test".
I'm running 38 audiotracks @ 44.1k 24 bits @ 4ms XTC mode, 60% of the 2 UAD-1's, etc atm.
Working without any glitches.
eh, you're right,
I am a luna(t)ech!
