Noah and SFP not playing nicely
Joxer the Mighty
I just picked up a Noah EX. Install went fine, Sonar 3 is sending midi through USB and the Noah is receiving it. I can hear the output through Noah's headphone jack. My problem is that in Sonar I can only choose either the Pulsar's asio drivers, or the Noah's. If I choose Noah's I don't have access to my SFP instruments and vice versa. What am I missing? I know it's probably something obvious, but I can't find the answer in any of the manuals. Any tips on how to get both systems working harmoniously would be greatly appreciated!
- Mr Arkadin
Joxer the Mighty
the fact that you can't activate SFP's and Noah's Asio Drivers at the same time is NOT a problem of creamware. This is the fact that Sonar is only supporting one driver! Same in Cubase. Emagic allows two diffrent drivers, but i think not the same kind, something like one Asio and (let's say) a wdm driver.
This also a synchronising problem, but it would be nice, that's true.
It should be possible to use SFP and Noah at the same time in Cubase, if they both are using the same Asiodriver!
Example: i have two RME Hammerfall DSP PCI cards running in my PC and working with Cubase, they using exactly the same driver. A Multiface is connected to each of the Hammerfallcards and i synchronized them via wordclock. Works fine!
Maybe one day Noah can work like another Pulsarcard together with SFP....???? So we have to wait what comes after SFP4. A Noah update would be nice anyway. Until then, connect Noah via Adat to SFP.
Joxer the Mighty
Nebukadneser
I have Luna II, Pulsar I and Noah EX, and separately the units work flawlessly. However, when running Cubase SFP 4.0 and Noah remote, my system crackles a lot. I believe the problem has to do with the latency settings. When i reduce the ULLI to 25 ms, the crackle is almost gone. At 3 or 7 ms, it is useless.
Is it possible to better synchronise the units?
regards
Neb
regards
Neb
Nebukadneser
Nebukadneser
marcuspocus
R.D. Olivaw
marcuspocus
R.D. Olivaw
it's the same ! the wordclock is the point.On 2005-02-10 02:18, marcuspocus wrote:
can't slave noah execpt with wordclock, 'cause noah doesn't have adat in....
when you slave hardware to its adat input, you are slaving it to the wordclock coming from the adat input.
in this case there are pops because there is a digital connection between hardwares that does not share the same wordclock.
your SFP is on the emu clock (via adat) and the problem is that the noah is on its own.
if you connect the 6400's BNC WClock OUT to the noah BNC WClock IN, the noah will be slaved to the 6400, exactly the same way it would have been if it had an adat input to slave it to the 6400.
Everyone will then have the same WordClock, coming from the e-mu, and the pops won't happen anymore (assuming the wordclock was the only problem).
marcuspocus
