I am having this problem over and over and can't work it out..
Problem is shutdown Sfp, open sx to and messages- test current ASIO-MME configuation, i click yes and says- card is currently configured to accept a digital signal and no digital signal is present.Reconfigue card to use an internal clock or apply a digital signal, or if possible switch this port to accept an analog input.
However this only happens sometimes with Sx and other times i can go straight in ?? Without sfp shut down it works perfect
The card-pulsar 2- is set as master internal clock, going to a analog mixer. P4 computer
						Sfp,Sx, Xtc prob
Skip the MME (Wav drivers) test, use ASIO Scope drivers instead.  The reason you're getting this error only in XTC, is that the wav drivers are loaded in your normal project and not in the XTC project which is loaded under the skin...
Ok i disconected the wav source in normal project window and still same prob..skip the test and sx control panel asio scpoe is selected, no success.I also have loaded a xtc,sx, project that was screen shot in the tips section but i have only the basics compared to you guys. How do i post a screen shot up on this site? Maybe someone can screenshot a simple set up.Pulsar 2 sfp 3.1c
