I told you a friend has a noahEx, that he just lent me for the week end (by the way, you will hear an LP made in digital performer and 70% with Noah : Polaris LP on Neurobiotic, not out yet (only the LP tracks have noah).
So I have it for the week end and made a few tests.
First, I installed it on the same machine as SFP. It does work fine in all aspects :
1. Drivers can run in cunjunctions with SFP drivers, the orders of midi/audio drivers did not change in my projects (it happened to me with pci cards, where you have to reset all your midi tracks output, because the order of driver changed). So all is fine.
2. I installed Noah on its own usb interface : the midi is sent/received on the usb interface (whereas SFP still uses pure midi/seq source/dest). It means that I can send a note to noah thru usb, get it back thru usb or midi (midi in Echo function of noah) to record controller movements, or to send midi somewhere else. It also gives me 16 midi channels and an additional midi chain, as you can also echo usb to "true" midi out.
3. I can use the step sequencer to control external synths (here i have minimax playing with dx 100 and another step sequencer playing Juno alpha. I'm impatient to try with the EPS16+)....
4. I had a look at presets tro see if I could convert sfp presets to noah thru midi CC : well, noah midi CC are fixed values, which means I would have to build a midi CC preset for SFP, which matches Noah CC numbers... I didn't do it (I have more interesting stuff to do sorry
 5. It is cool to run 4 synths externally, it keeps SFP lighter, and may be i can do most tracks in a "live" configuration before mixing/overdubbing/whatevering.....
6. I can archive presets and "multipresets" (like projects in SFP) in noah rom, compact flash, or hard disk (and do all manipulations for backups/restore etc).
7. not enough effects in the inserts, i could well manage a 6 inserts slots on each synth slot and master out
 ...Very good machine for synths.
6. I give it back tomorrow evening...
I'll have a look later if you have quick tests ideas, but i prefer to warn you that i'll be doing music with it so i'm not going into demoing noah
 <font size=-1>[ This Message was edited by: spacef on 2004-03-06 04:07 ]</font>
<font size=-1>[ This Message was edited by: spacef on 2004-03-06 04:09 ]</font>
