This file has expired and is no longer available here. The owner of the topic can re-upload the file, or post a link to an off-site file. <BR><BR><a name="planetz-tag"></a>Genre: Strange<BR> <a name="planetz-tag"></a>Uses: Pulsar Synths<BR> copyright © Kamurah<BR> _____________________________________<BR><BR> Here is a short demo file with comparisons between the two at the same filter settings. Nothing fancy, but you can get an idea of the sound comparison.
1st set in each of the sequences is the Minimax....second repetition is the Arturia.
Minimax Vs Arturia Minimoog
Shayne White
Yeah, MiniMax sounds way better. Not only is the tone better, but it doesn't have a steppy filter.
Shayne
Shayne
Melodious Synth Radio
http://www.binary-sea.com
Shayne White
What I don't get is when people like Bob Moog and Jean-Michel Jarre endorse these things. They ought to know better.
Sorry, I didn't save the project...it was just a little test.
But all I did was:
1. Have all 3 OSC's on and set to saw, same octave
2. no detune on oscs
3. cutoff 100%, Res 0%
4. soft clip off on Arturia
5. no effects
for the 1st section it was played as is.
The second section I turned the cutoff to 15%, and made a MIDI file of the res sweep. I copied the res sweep data to both instruments and recorded the output.
I don't remember the exact settings on the third section....sorry.
Hope this helps.
But all I did was:
5. no effects
Hope this helps.
Basic Pitch
