A multi-client, multi-channel ASIO source device would be very nice. It should be able to route multiple sound sources (like ACID, DAW, Rewire, Sound Forge, etc) to the Pulsar using ASIO. This way you don't have to use the Wave devices (low latency!).
Multi Cllient ASIO source
wolf
Asio has neither to do with vst (beside both formats come from steinberg), nor with rewire (which was developed by propellerheads).
Asio is about how to talk with a piece of hardware, while vst is about the communication with a plugin running inside a host app and rewire is the conversation between two independent apps with 64 samples jitter.
The capability to access a multi client asio driver (e.g. rme has one) depends not only on the driver, but on the host app, too.
Better said the host has to have the ability to select a given amount of the existing asio streams. This is implemented very different in the several host applications if at all ..
Having said that, has anyone ever tried to limit the asio inputs inside the host to access the other streams with another app ?
I have sfp running on a separate pc, so I'm not using asio there anyway .. but on my rme/logic/ableton combo it works. ... well, not really fine (drop outs, clicks, etc.), perhaps for that the pcs still are to slow
best
Wolfgang
worldless productions
<a href="http://www.worldless.com">worldless.com</a>
<font size=-1>[ This Message was edited by: wolf on 2004-04-01 12:33 ]</font>
best
Wolfgang
paraceta
I tried to connect two sources (Sound Forge) to one Scope ASIO driver, but the first app took absolute control of the connection, no matter how many channels were used. IMHO technically it should be possible to write code that presents itself as an ASIO driver to multiple clients, but is in fact 1 multi-channel driver.
