<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Utility<BR> <a name="planetz-tag"></a>Related To: Samples<BR> <a name="planetz-tag"></a>Requires: Windows P.C.<BR> _____________________________________<BR><BR> Beta1 of the 'BPM Calculator' (based on a sample).
Note: the .zip file currently also contains comdlg32.ocx - if the .exe doesn't run, then copy this .ocx file into the System32 directory and all should be well. I'll remove the need for this by writing my own file open dialog ASAP and build that into the application.
Use:
Run the executable
Click 'load' - a standard file open dialog appears
Select a sample (*.wav only)
The BPM is displayed! (for 4 bars of 4/4 as default)
Clicking the 'info' button brings up some information regarding the sample
At this stage, you can change:
time signature (3/4 or 4/4 only at the mo)
#bars - 0 through to 8
#beats - integral values only
Each time the bars or beats are changed, the BPM is recalculated
If the sample file is looped, the calculations are based on the length of the loop.
If the sample is not looped, then the calculations are based on the entire sample length.
Click 'quit' to exit.
Limitations:
3/3 or 4/4 time sigs only
BPM rounded to two decimal places
0 or 1 loops only!
PCM format .wav file, loop information is in the 'smpl' data chunk
Does not consider the potential "fractional sample" as part of the calculations (probably wouldn't make a lot of difference!)
Windows P.C. only
Only whole numbers of beats can be entered.
Note: if bars & Beats are both 0, then no BPM is displayed (can't divide by 0!)
I've done some preliminary testing, but would appreciate it if somebody could check some 'known samples'.
Regards,
Royston
<font size=-1>[ This Message was edited by: Counterparts on 2004-02-25 08:02 ]</font>
Wav_BPM
Wow =) Thanx man !!
I'll try it out tomorrow. have to sleep now.
Been up for ehm.... hmm... 52 hours =).
aahaaaa so thats why my room is upside down!
I'll report my progress with your device in short !
Nice work!
Love to you all =)
(I Praise JAH)
<font size=-1>[ This Message was edited by: Jngaelin on 2004-02-29 20:22 ]</font>
Nice work!
Love to you all =)
(I Praise JAH)
Counterparts
