This file has expired and is no longer available here. The owner of the topic can re-upload the file, or post a link to an off-site file. <BR><BR><a name="planetz-tag"></a>Genre: Electronic<BR> <a name="planetz-tag"></a>Uses: Pulsar Mixers<BR> copyright © 2004 Sybil's ORbit<BR> _____________________________________<BR><BR> I have been playing with Apple's new "GarageBand" application and basically threw all these loops together into some kind of order. I only used Pulsar to master and do the final mix.
It's not great - but it aint that bad either?
Generic Tasty
first time I hear some audio from it, thanks
Nit bad at all, I just would have choosen other drumsounds, but I see thayt's not the point here
I downloaded 30 MB free loops great from Art Gillespy this morning, the man behind Bitshift Audio/Phatmatic Pro.
They are Garage Band suited, but of course you also can use them 'standalone'.
If you have Phatmatic, check it out: http://www.bitshiftaudio.com/news/archives/000058.html
cheerz
cheerz
- AudioIrony
Yeah, I downloaded those Bitshift loops and also the Access Virus loops for GarageBand.
You can still get the Access Virus loops from the Access site or search for it on http://www.macupdate.com
It's not a pro application by any stretch, but it makes it easy to throw together sub mixes and loops for use elsewhere.
There are some great built-in effects like the double filters etc, the only problem being is that resonant filters don't reset on stop or rewind, so you have to keep reloading your song to hear the true effect especially if you have long slow filters over many bars.
Midi programming is a bit dodgy too, although I found out I can use my Audio Units version of Absynth or any other AU instrument or effect for that matter.
Not too bad for $75.00 AUD - for the whole iLife package.
Cheers
Brett
Cheers
Brett
Neil B
Really enjoyed this one, however it was put together
Tasty piece of music from you again Brett - I was kinda wondering what you were up to. Last I heard you were still looking ata fence with panties on your head
Liked the vocals in terms of the voice. Lots of cool sounds. Only problme is that I'm going to have to change some of the notation and chords on the track I'm playing about with - we must've been thinking along the same lines.
I could listen to a lot more like that if you upload them.
- AudioIrony
Tasty piece of music from you again Brett - I was kinda wondering what you were up to. Last I heard you were still looking ata fence with panties on your head![]()
Fences no longer hold a fascination for me as I find their conversation and logistical skills lacking - especially the treated pine ones!!!
Anyway, back to the music - yup, thrown together it was. I used mostly the Access Virus samples I downloaded and the vocal samples were from Computer Music magazine - "Urban Source" - the one with the XXX rated phrases
GarageBand was pretty easy to work with - no messing about with time stretching and beat matching - all done for you - but it's not good enough for final mastering.
I think I will enjoy putting together loops and filtering/mangling them for import into Cubase and STS 4000.
look forward to hearing what you've been up to Neil, are you using similar samples?
Neil B
I couldn't make out everything in the vocals, so if I've complimented you on any "xxx" ones, let me know and I'll go and iron my tongue
Glad to hear the fence phase is over - lamp posts are quite intelligent if you're lonely.
I'm not up to too much, and no, I'm not using the same samples. Bit of a dry phase I'm afraid, so I took the opportunity to do a bit of research while putting something simple together and trying to improve the mixes if not the music
Surprise in store when and if I upload it though - but don't hold your breath.
In terms of vocals - have a look at the Lola and Leon thread I've started in the Off Topic Forum - perhaps best not to do a search on "Lola" though
- AudioIrony
It's OK - I played it safe, I used pretty tame phrases - they're more suggestive than anything. No need to iron your tongue unless your sick of the AfroOn 2004-02-25 10:25, Neil B wrote:
I couldn't make out everything in the vocals, so if I've complimented you on any "xxx" ones, let me know and I'll go and iron my tongue![]()
Lamp posts are few and far between here in Australia, which is probably just as well!!!Glad to hear the fence phase is over - lamp posts are quite intelligent if you're lonely.
Checking out "Lola" and "Leon" as I type - although it's for windows only - So I'll have to stick with the Electric Monk for the momentI'm not up to too much, and no, I'm not using the same samples. Bit of a dry phase I'm afraid, so I took the opportunity to do a bit of research while putting something simple together and trying to improve the mixes if not the music
In terms of vocals - have a look at the Lola and Leon thread I've started in the Off Topic Forum - perhaps best not to do a search on "Lola" though![]()
