System Config:
Intel D875PBZ
Intel P4 3.2GHz, 800MHz
Corsair TWINX1024-3200LLPRO 1GB DDR400
ATI Radeon 9600 XT AGP 8X 128MB DDR
2x Seagate Baracuda ST3120026AS 120GB SATA
1x Sony 48x CDRW
Thermaltake Xaser Silent Purepower480W PSU
Zalman CNPS7000A-Cu CPU Cooler
Zalman ZM80A-HP Silent Video Cooler
DSP Cards:
1x Creamware PowerPulsar
1x TC Element
1x UAD-1
Misc:
Steinberg Midex 8
Netgear MA-101 USB Wireless LAN
Belkin USB 1.1 Hub
OS: WinXP Pro - NTFS
HT is enabled
Install Notes:
Everything came in good condition, no complaints at all. Both the PowerPulsar and TC Element were new as well (I used a Pulsar II before this), so a lot of parts were going together at the same time. Total system build was a solid 5-6 hours (just parts - no OS)... yeah, quite a bit of time. I'm a freak about cabling and what not, so it took time to get everything into place. Those Zalman coolers are VERY heavy! It's a good thing this case won't move much if at all. The silent heat-pipe cooler for the video card took 45min alone to put together, but I think it's well worth it. One less system fan and it seems to stay very cool to the touch.
There were a couple scary moments. I wasn't expecting exactly how big the PowerPulsar card is which means *HUGE*! I originally planned to put that card in Slot 2 (no IRQ sharing), but there's a rather large capacitor on the card that blocks the 2nd SATA port.
WinXP install and all drivers went in without any problems what so ever. Same for Cubase SX and my native synths/plugins.
Slot Assignments:
Slot 1 - N/A (Zalman video cooler blocks it)
Slot 2 - TC Element
Slot 3 - UAD-1
Slot 4 - Creamware PowerPulsar
Slot 5 - Free - probably will Firewire card
Case Enviroment:
1x 120mm Rear Fan (Pabst low noise)
1x 80mm Front Fan (Pabst low noise)
CPU Temp: stays between 39-45C under load
CPU Heatsink: just slightly warm
Video Heatsink: just slightly warm
All the DSP cards are pretty warm while the UAD-1 is hot (as it was before). This concerns me a bit, so I might place another 80mm fan on the side of the case blowing directly on cards (couldnt hurt anyway). According to the Intel Active Monitor App both temperature "zones" are 37C.
- I'd like some advice on system / case temperatures if anyone can offer them -
IRQ Assignments:
IRQ 0 System timer
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
IRQ 6 Standard floppy disk controller
IRQ 8 System CMOS/real time clock
IRQ 9 Microsoft ACPI-Compliant System
IRQ 12 Microsoft PS/2 Mouse
IRQ 13 Numeric data processor
IRQ 14 Primary IDE Channel
IRQ 15 Secondary IDE Channel
IRQ 16 RADEON 9600 SERIES
IRQ 16 Intel(R) 82801EB USB Universal Host Controller - 24D2
IRQ 16 Intel(R) 82801EB USB Universal Host Controller - 24DE
IRQ 17 Universal Audio UAD-1 DSP card
IRQ 17 Intel(R) ICH5/ICH5-M SMBus Controller - 24D3 (Intel(R) SMBus 2.0 Driver)
IRQ 18 Intel(R) 82801EB USB Universal Host Controller - 24D7
IRQ 18 Intel(R) 82801EB Ultra ATA Storage Controllers
IRQ 19 Intel(R) 82801EB USB Universal Host Controller - 24D4
IRQ 19 Creamware Scope
IRQ 22 POWERCORE
IRQ 23 Standard Enhanced PCI to USB Host Controller
Ideally I wanted the Creamware card on it's own IRQ, but it seems happy so far. Either I got a little lucky or the Intel boards are just very stable.
Inital Test:
Please keep in mind I haven't spent much time running the system - only about 12 with 6 of them in actual audio apps. I took one partly finished tracks and starting loading the DSP cards until I felt it was time to stop.
I understand this is not a "scientific" test and isn't going to please everyone. It was basically just to prove to myself how the system was initially doing and a somewhat fair representation of the most I'd push the system on a "normal" track.
I loaded each DSP card as much as I could until audio degradation was heard (generally a combination of pops and digital distortion). Even when the cards were overloaded it was easy to recover and remove the offending plugin. No system crashes, lockups or what not happened.
Test track:
Cubase SX 2.0 - Multi-proc. enabled
24bit / 44.1 Project - 10min length
Audio Tracks:
24x Stereo
6x Mono
Native synths running "live":
1x Waldorf Attack (approx. 6 voices running)
2x Novation V-Station (approx. 4-5 voices)
1x NI Kontakt (3 instruments)
1x Steinberg D'Cota (3 voices)
Native plugs running:
2x Ohmboyz delay
1x Cubase Flanger
DSP Plugins:
UAD-1: (running 92% total)
1x LA2A
1x Pultec
6x 1176LN
TC Element (approx 50% on all 4 chips):
4x ClassicVerb
4x Sony Oxford (demo)
1x Sony Inflator (demo)
1x PowerCore CL
1x TubiFlex
*Note* - The TC had plenty of headroom left, but adding in any other plugins induced cracking most likely due to PCI bus limitations,
Creamware PowerPulsar (approx 75% of DSP):
1x STM1632 Mixer
2x Vinco Compressor
2x MasterVerb Pro
2x MiniMax synth (1 voice each)
1x Vectron Synth (3 voice)
1x Modular III "Flange Pad" patch (3 voice)
During "Test"
CPU: 20-22% (Cubase Meter) 25-28% (Windows)
RAM: 423MB
Disk Activity: nothing on cubase meter...
NO CLICKS OR POPS!! Project would start and stop fine with no studdering. I could freely move about any of the Cubase or Creamware windows without the typical noises I had before.
This test easily represents the max I'd ever use in terms of DSP. If I needed more EQ or compression I could always turn to native plugs with easily another 30-40% CPU to spare.
All in all I'm quite happy so far and would recommend any of these components to someone. I'm especially pleased that 3 high performance DSP cards (different brands) all play together quite nicely in the same box so far. HyperThreading is going just fine with both Cubase and the PowerPulsar environment which seems to be very hit and miss with a lot of users. Not a single crash with the system yet even as I was intentially overloading all the DSP systems which is outstanding. Kudos to Intel for building such a solid board.
Thank you to everyone who gave me advice during my purchasing phase!
Comments / questions are welcome.
<font size=-1>[ This Message was edited by: sinix on 2004-02-21 14:39 ]</font>
