Kick compress + compress + compress + ......
- astroman
just do it
(according to J.B. Tribout)
it's not uncommon, recently someone bragged in a production report about their 'most expensive 909 in the world' (3 outboard compressors if I remember right), but even KimGR prefers multiples from time to time to not miss a thing
Each device emphaszies it's own aspect of sound, if you don't take it too far.
to add something different: I once took a bassdrum sample from a 12" dance production, and put it in my mix.
After the usual mastering process the bassdrum wasn't as great as it was originally...
Be carefull, use your ears, if necessory keep certain stuff outside the (pre-) compressing processes.
AND: since I discovered the blessings of the PSP Transient designer I tend to push the attacks of some tracks a bit, to bring them in front of the speakers.
Even after heavy mastering compressing the profits of this in the endmix is more than good
, so the picture is rather complicated.
Astro quite rightly emphasizes the different character of different compressors (including Vintage warmers I would say), and in fact I mostly end up with different compression types (including vintage warming tape saturation types), but compressing several times with the same compressor...hmm, I don't know...dubbelcheck what you get at least, specially watch the punch...
cheerz
cheerz
- valis
3 compressors with gentle settings (getting more progressive in the chain) in a row is an often used in both mastering and to achieve *very* transparent compression. The reason for this is that no one device is going to overreact, so they tend to even out and with the right gear can also gently 'warm' the signal.
samplaire
Michu
i think this is what RNC's Very Nice mode is about.On 2004-02-18 03:17, valis wrote:
just because you cannot imagine something that doesn't exclude it from reality.
- valis
thanks Valis, about the RNC compressor (which I didn't knew), I checked http://www.fmraudio.com/ , but I couldn't find anything like you say here about a three stage compressing technic.
I believe you, but I just would like to read more about it...you know where?
Eric Dahlberg
Another way to use multiple compressors - especially when mixing a live drummer -is to use the first one to control dynamics & the second one to shape the actual sound. In this way you can get a more consistent level & attack.
Uncle E
JRR Shop
TEL: 949-553-8898
FAX: 949-263-1818
http://www.jrrshop.com
http://www.justroots.com
JRR Shop
TEL: 949-553-8898
FAX: 949-263-1818
Michu
- valis
Thanks for catching that michu =]
Incidentally I've only got 1 rnc atm but my next purchase is probably going to be a 2nd RNC with the 'funk logic' rackmount that gives u a black front to boot (stock rnc is white):
http://store4.yimg.com/I/mercenary-audio_1778_6784640
