Hey there,
I'm using my Pulsar 2 solely as a DSP card with a Delta 1010 card and Logic 4.8 on Windows XP. The basic problem is that I can't seem to play any XTC synth track in Logic from my midi keyboard. However, if I have a midi sequence in the XTC synth track, that will play back fine (as long as I have any track highlighted except for the XTC synth track -- ???). SFP mode works fine.
More details: I'm not using the Pulsar hardware connections at all, so I have all the IOs disabled in the XTC Settings (this doesn't work even with the IO settings enabled). Midi is coming from my keyboard into my Delta 1010, which sends it to Logic. I can set up other VST instruments fine, except for Creamware's. I'm using the xtcproject.pro from http://www.planetz.com/forums/viewtopic ... forum=14&0. I have not edited the ussi parameters in cset.ini at all.
Again, I can play back a midi sequence on the XTC track as long as I have ANY track highlighted EXCEPT for the XTC track itself. And I can't trigger the XTC synth from the Delta 1010 midi no matter what I do.
Ideas anyone? Help would be much appreciated! My apologies if this problem has already been addressed -- I've looked through the past posts and haven't been able to find a solution.
XTC synth MIDI connection problems with Logic and XP
