I made this one to use with my Roland midi converter.
Basically it's 6 synth basic circuits receiving on 6 different channels, made of Wavetable osc's, individual envelope and vca, all mixed and sent in parallel to Poly filter, Vocal filter and 24db lowpass.
Roland GK2 pick-up sends CC #11 both with knob and synth switch, so they work both on a slider in the patch.
It can provide guitar sound both aside osc's before filtering section and after filters before the effects.
I used a constant to modulate all individual envelopes times, it can soften attacks and releases for all the channels, provided they are not at full zero position, not strictly necessary but useful sometimes.
I made very few presets, as you could add a section for the guitar sound or other osc's if you have dsp. I used the wavetables because they are very flexible and dsp economical, but you could add or change them. Obviously you throw away the presets then, and make them from scratch.
It works very well here with a GI-20 interface and a hard pick.
Cheers
