Kamurah's smoove with different eq
This file has expired and is no longer available here. The owner of the topic can re-upload the file, or post a link to an off-site file. <BR><BR><a name="planetz-tag"></a>Genre: Lounge<BR> <a name="planetz-tag"></a>Uses: Pulsar Mixers<BR> copyright © Kamurah<BR> _____________________________________<BR><BR> I eq-ed Kamurah's Smoove in the lows, and did some other suggestions here .
Note: sure the sound of the low freqs is not really beatifull now.
It's meant to show you can change the balance between the bass parts (bassdrum and bass synth) and the rest without any problem.
A dj will love a big sound, it works better on sound systems and people take the lousy basses as a sign to dance :smile:
Probably you'll then also have to check the snares and hihats, may be they need to be a bit louder coz of the pumped up bassdrum.
It all depends on if you can keep the mix empty enough, in an open mix the guitar will bite easy through the mix even when it's mixed in with a lower level.
But you should do what you want of course, I just like it and heard in my head how it would sound if etc.
cheerz :smile:
...whatever you do, keep the 'break' at the end exactly like it is, without any bridge notes or fills, it's lovely and cool :smile:
Let There Be Music!
<font size=-1>[ This Message was edited by: hubird on 2003-12-28 21:40 ]</font>
Nestor
Post by Nestor »
It gives to it quite a different character, it is now more like film production to me, the way it has been mixed and eqed.
