Well, i bought the XTC installed it , used its effects and instruments it seemed ok, after i closed the Cubase SX and loaded the project with the XTC effects it seemed like the FX are on but they dont work ! when i try to open the fx it wont open the surface,i tried to install a newer version of cubase sx,itried the 1.0.5 and its still doing me that problem ,i tried reinstalling the SFP program and it stay the same,and this track is only at the beggining its not like to complicated or something.
well in previous project it was doing me the same problam but after i inserted the FX once again it loads the FX only if i open a new project before and loading some XTC FX and then open the project,if i wont do it before it tells me "the plugin failed to install" well i dont know why or what causing it ,its realy annoying .
anyone got an idea what causing it ?
Thanks.
New to XTC and it s driving me crazy !
Uninstall everything first, start clean.
Then follow this order:
1- install driver for xtc only, NOT the sfp app...reboot
2- Install SX2...reboot
3- Install sfp, and in the dialog where it ask you vstplugins directory, in the first directory point to the vst plugins dir of sx2, in the 2nd slot, put c:/sfp/VSTPlugins
4 - reboot
5- start Sx2 and test
4 - reboot
