<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/pre ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Related To: Analyzer Tools for Windows (98/XP)<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar All Versions Ok<BR> _____________________________________<BR><BR> Hi Guys,
As most of you referred, here is the Windows Oscilloscope Test Program for Digital Audio WorkStation, which also uses wave-in and wave-out drivers by the Windows's default setting...
Program's Screenshot can be found as follows:
http://www.geocities.com/dsp4studio/Osilloscope/
Instruction:
Unzip file then launch the program. No installation required. See the included Quick Reference User Manual Documentation.
Requirements:
* Windows98 or better (XP is recommended).
* CPU: 500Mhz+.
* 256MB RAM+ (512MB is recommended for XP).
* Video Setting: 16/24/32Bit - 1024x768 (32Bit-1280x1024 recommended).
* Soundcard: Windows compatible full-duplex Soundcard.
Features:
It has more than just the Oscilloscope, lot of features with Friendly Graphical-User-Interface (Hopefully). You can have multiple programs at once (simultaneously) with very little CPU taking performance (1/2-3% CPU per instances). See the summary Feature and Specification as follows:
* Voltage input level: -1V to +1V.
* Gain and offset: 15 parameter setting from negative to positive gain offset.
* Overflow Detector: Clipping/Overflow Indicator LED.
*Timescales: Selectable timescales from 1-45ms.
* Trigger: 0-1V (1-5mv steps).
* Skins: Three Selectable skins like Contemporary (Default), Classic and Custom Skin.
* Display Styles: 5 display Styles and 3 color mixed styles like Dots, Lines, Conlines, Spikes and more...
* Preference: Wavein and waveout drivers enhancement for Windows setting like CPU priority (normal, high and Realtime) and sample buffer setting. All these changed can be done on fly without any restriction order.
* Performance Display: Built-in the Display for DSP/CPU, Refresh rate and waveform style monitors.
* Single trigger Events: It can holds the waveforms, based-on the timescale setting until retriggering (Trigger Option).
* Function Generator and Waveplayer: Built-in waveform generator (Sine, Square, Triangle, Noise and external wave) and Wave tester as standalone operation. It can be used as similar Waveplayer with standard wave formats without Winamp needed, for example. It also has the Selftest capability and more in General Purpose used...
Please note that, this Program is as beta test version. Of course, we have always wished to hear from you that how you like it!
Enjoy it!
LongStudio
<font size=-1>[ This Message was edited by: LHong on 2003-12-27 21:20 ]</font>
						Windows Oscilloscope (Analog Modeling)
would be fantastic if it showed gain+freq over a timeline (like if it was seen from above)
vertical : timeline
horizontal : frequency
color : gain (from black to white for ex,with temprature colors in between).
like dsp spectrum tool which was available for winamp once. i never saw a more informative analyzer... you could see every note you play, even in guitare chords or whatever....
<font size=-1>[ This Message was edited by: spacef on 2004-05-06 04:33 ]</font>
						vertical : timeline
Leper,
Later version we shall have the assignable wave drivers for each instance (even in same soundcard like Scope/Lunar/Pulsar) Is that what you want?
Thanks,
LongStudio
Thanks,
LongStudio
On 2004-05-05 19:38, Leper wrote:
Looks great, but I can't use itIs it possible you could add a setup screen to choose which soundcard/driver to monitor? My windows driver is set to my Soundblaster Audigy, and I use that for my speakers.
Thanks spacef,
I'm also working on the audio analyzer and wave analyzer application, might be it will implement the way like your idea...
Refer to the traditional Oscilloscope, We try to keep it be similar, if you want frequency analyzer then use the Spectrum analyzer. I know most of you want all-in-one apps but it might never be enough! How about the combo of Scope and FFT Spectrum?
Best regards,
LongStudio
Best regards,
LongStudio
vertical : timeline
Cool! We are working on this, it will look similarly, except more professional, it's called Spectrogram Analyzer and be soon to share with all of you...
is it what you have in mind? Mind you, Not many people know well or really wanted it. I'm glad that you like it.
Thanks spacef,
Best regards,
LongStudio
Thanks spacef,
Best regards,
LongStudio
<font size=-1>[ This Message was edited by: LHong on 2004-05-08 17:08 ]</font>On 2004-05-08 03:24, spacef wrote:
well if you want to make a spec analyzer one day or another... keep the idea... (ps : pic = begining of guitare solo in gene vincent bebop a lula). it would look better fliiped as a piano roll....
<font size=-1>[ This Message was edited by: spacef on 2004-05-08 03:37 ]</font>
