Shayne
Buy as many CW cards as possible!
Shayne White
What better tip can you give than that??
Shayne
Shayne
Melodious Synth Radio
http://www.binary-sea.com
OK OK .. I followed your advice, now ive got pulsar II + pulsar I card.
Q: How do i make them play nicely and what do i need to do to make them work together?
Q: I bought them both secondhand so there maybe information that i am missing( manuals , instructions, tips and tricks), would love to have them working in my PC
i read that the order is important.
Hmmm help? I asking u guys/gals cos Im a noobie in this world any help would be greatly appreciated!
I read the powerstrip/ doubledawg tip to stop crackles by changing the PCI latency .. Very Interesting!
TIA
TIA
Shayne White
Well, to use them both together you need an S/TDM cable which you can order from any CreamWare dealer (I like JRRShop personally). The Pulsar1 has one connector, and the Pulsar2 has two, and I don't think it matters which connector on Pulsar2 you plug the cable into. (They're located on the top of the cards.)
The Pulsar2 should be placed further away from the video card than Pulsar 1, as that position on the cable will make Scope detect it as the primary card. Otherwise you have to do cset.ini modifications.
Since you're doing two cards, use the two ends of the cable, not the middle joint.
Boot up your computer and fire away!! Have fun!
Shayne
Shayne
