Hiya,
Would it be possible to split my setup ?
Let me explain: I got a Pulsar II, PowerSampler and Luna II, all connected by the STDM cable.
What if I disconnect one of them, like the Pulsar II for example and use the PS + Luna II in SFP mode and the Pulsar II in XTC mode. Would this be an option ?
Thanks in advance,
Ronald
P-III 1,4Ghz - Asus TUSL2-C - 512Mb RAM - Matrox 400 - 2 x 17" LCD - 2 x 40Gb - Pulsar II - PowerSampler - Luna II - 2 x breakout box - Logic 5.5.1 - Logic Control.
Sounds like fun.
<font size=-1>[ This Message was edited by: RoonSmits on 2003-11-14 15:45 ]</font>
Splitting setup ?
RoonSmits
kimgr
- valis
RoonSmits
Thanks for your answers,
I thought it wouldn't be possible.
Just wanted to hear you opinions before I opened up my system.
Thanks again
Ronald
PS the multiple computer certainly is an idea, I guess I'd go for a RME Hammerfall in that case to link 'm up via ADAT.
Build myself a new DAW and use that only for VSTi-s and FX ? Not a bad idea at all.
<font size=-1>[ This Message was edited by: RoonSmits on 2003-11-15 15:55 ]</font>
Thanks again
Ronald
- valis
This is exactly what I was thinking of suggesting and there are several other users around who do/have done that. The hammerfall is nice because the control software allows your adat i/o from the Creamware cards to be either routed through the hammerfall breakout box (Multiface?) either into the pc or out to the rest of your studio/mixer...On 2003-11-15 15:54, RoonSmits wrote:
RoonSmits
Well,
I guess I'd use the other computer as one large FX rack indeed. The ADAT lightpipe will be the best multi-channel option for this. Since I went all digital and ditched my analogue gear a year ago, I'll use Logic + LogicControl + the main outputs of Pulsar to my monitors. This way it will still be one system with no AD/DA conversions.
That new machine will be faster and more powerfull, sure, but I see no reason to rebuild my current DAW it does the job just fine.
Hyperthreading and dual processors aren't Creamware's biggest friends, but I'll have a look on the RME forum to see if this is a problem with their cards. If not, then maybe I'll build myself this dual Xeon 2,66 at the end of this month. Nice early X-Mas present I'd say
Peace
Ronald
Peace
Ronald
P-IV 3,2Ghz pc/Pulsar II/Luna II+ADAT exp./breakout box/PowerSampler/Logic 5.5.1/Yamaha CS1x.
- valis
Same here, my dual Xeon has been in operation almost 2 years now and the only complaint I have is that the damn cpu fans are the only thing I can't quiet without using a hacksaw on these wind tunnels to make Zalman etc fit properly. Someday I'm going to get around to building a 3-pc ventilated case so the 3 pc's in here are just a non-issue for white noise.
