A client was having problems with a Creamware Pulsar 2 and Gigastudio, so I swapped cards with him and installed the P2 card on my machine, and registered with Creamware. I'm having the same problems. Set up the P2 midi-in and it works in ASIO apps like Reason. However, trying to switch GStudio to use the P2's midi-in, GStudio greys out the audio card and wont send any audio or receive midi. Tried re-installing GStudio and SFP 3.1c drivers. Finally got it working after running Reason, then switching to GStudio, opened Scope, noticed that the GSIF device had "disappeared" from the routing window (I have no idea why, but it was there before when I was testing GStudio). I re-enabled GSIF and now midi-in works and audio is going out analog 1-2, however GStudio still shows all audio outputs greyed out.
Also, I get this error message when Reason loads (GStudio not running):
"The Procedure entry point CloseBackgroundProject@ScopeApp@@MAEXXZ could not be located in the dynamic link library RADI.dll"
Repeated emails to Creamware have not even been acknowledged.
