All you need to do is... right-click on an empty Desktop spot select New Shortcut type shutdown followed by a space, and then enter one or more of the parameters listed below click Next type a suggestive name for your new shortcut finally, click Finish.
This is the Shutdown.exe (located in %systemroot%System32, usually C:WindowsSystem32) syntax:
shutdown [-i|-l|-s|-r|-a] [-f] [-m \computername] [-t xx] [-c "Text"] [-d[p]
Valid command line switches:
-a = Abort system shutdown in progress ONLY IF the -t xx timeout option was already set to ANY value other than 0. ALL switches except -l and -m are ignored during abort.
-c "Text" = Text comment (case insensitive) to be displayed in the Message area of the System Shutdown window. MUST be enclosed between quotes. Maximum allowed 127 ASCII characters.
-d [p]
u = User code.
p = Planned shutdown code.
xx = Major reason code. Positive integer number less than 256.
yy = Minor reason code. Positive integer number less than 65536.
-f = Force running applications to close without warning.
-i = Display the shutdown interface (GUI). MUST be the first option!
-l = Log off the current user of the local computer (default action). CanNOT be used with the -m option unless the current user has Sysadmin rights, in which case the -m switch takes precedence.
-m \computername = Remote/network computer name (most always case sensitive) to log off/restart/shut down. Current user MUST have Sysadmin rights to be allowed to use this switch!
-s = Shut down the local computer.
-r = Shut down and restart (reboot) the local computer.
-t xx = Set shutdown timer to timeout for xx seconds. IF NOT specified defaults to 20 seconds. Allowed values between 0 and 99 seconds. The -a switch is the ONLY one that CAN be used during the timeout period.
NOTES:
The dash (-) in front of these switches can be replaced by a forward slash (/).
Spaces are NOT required to separate the shutdown command from ANY following switches, but ARE required to separate ANY switch from its following parameter(s), if any.
For example:
shutdown -s -c "Shutting down!" -t 3
tells your computer to shutdown after waiting for 3 seconds while the System Shutdown window will display text above in the Message area.
Optional: after you're done creating your customized shortcut for shutdown right-click on it select Properties enter your desired key "combo" in the Shortcut Key box (e.g. Ctrl + Alt + End) click OK/Apply.
From now on just left-click on your shutdown shortcut or hit that key combination to turn off/restart/log off your computer.
useing the reboot command ya can make 2 shortcuts on desktop one reboot one shutdown...drag to shortcut bar in taskbar and its one click.
