Startup crashes everytime, 2nd load always ok
otter
Post by otter »
Every time i start my PC, the startup project starts loading, then crashes and Winxp wants to send a bugreport.
If i start SFP again, everything works fine.
Tried reinstalling SFP
, rearranging IRQ´s and slots.
Maybe some registry thing?
Can anyone help?
#THX
Otter
Specs:
Winxp pro SR1/SFP 3.1C/CUSL2C/PIII 512MB/2 IBM HD 40gig&60 gig/Gainward 2MX Dual/
2x Pulsar II + 1 x Luna/Luna I/O Box/ Cubase SX/Midex8
<font size=-1>[ This Message was edited by: otter on 2003-10-26 09:50 ]</font>
Start > Run > "Msconfig"
It might be that something else is loading at the same time and conflicting?
Just a thought...
Omb
Post by Omb »
hello there,
i think valis is rihgt but i dont know whay
this is happend.
i have the same problem that my computer crash without eny worning or sx suddenly crash andwhen i restart sx it says that the asio is closed or some thing like that.
i have noticed that every time that it happed there is an entery in the msconfig at the startup tab that named : dumprep 0-k .
i have looked in the registery and found out
that it is related to the kernel file system
but i dont know how to fix it so i only unchaked that box in the msconfig and for some time it doesn't happend .
i have that problem for a long time and i even format my system but it came again after a while ... urg :sad:
its frustrating me too for a long time ,
Hope we can find the solution here.
my system is : P4 2.4 ,asusp4pe ,512 ddr kingstone ,80giga maxtor and pulsar2.
cheers,
Omb
<font size=-1>[ This Message was edited by: Omb on 2003-10-26 20:29 ]</font>
<font size=-1>[ This Message was edited by: Omb on 2003-10-26 20:30 ]</font>
http://www.greatis.com/regrun3atyouroption.htm#dumprep
Dumprep is just a meory dump created by the NT kernel (nt/2k/xp) when the crash occurs. You can disable these:
- right click on My Computer
- select "Properties" and then the "Advanced" tab.
- Click on the "Settings" button in 'Startup and Recovery'.
- In the bottom pane under 'Write debugging information' select 'None' in the dropdown field
- click OK
Omb
Post by Omb »
thanks valis,
did you try the RegRun Suite ?
Omb
otter
Post by otter »
thank you for your help, mates.
In msconfig , i saw that option for the startup project is "sfp.exe -s".So i tried opening sfp without "-s":worked tried with"-s" again:didn´t work .
Then I found the problem: one of the paths in "settings" (SFP toolbar) was deleted.entered path again, works perfect now.
