<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/pro ... .JPG"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Related To: Logic<BR> <a name="planetz-tag"></a>Pulsar Version: SFP 3.1<BR> _____________________________________<BR><BR> Hi everyone again,
A repeat of an earlier post but this time with my old setup using the Big mixer(which works the way I want it to by the way)
I am sure there must be something easy that I am not doing right. But I am trying to record Audio in Logic or Cubase and the mixers within those programs do not show a signal going in (LED meters not responding). I am also trying to record the output from my Midi parts and software synths(in essence the same thing). Now everything works within the Pulsar environment. There is a signal going in and it shows up in the LED meters.
i am sure there is a basic solution that I am not aware of. Please help. I should add though that when I use The Big mixer from Pulsar version 2 and use my old set-up it works. So I must have connected something incorrectly. By the way you may notice that the ASIO Source isn't connected, but I have it connected, so that is not the problem.
I will also include my old project using the BIG MIXER where everything works. But you will have to see another post <BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/projects/1Oldy.JPG" BORDER="0">
						Trying to record Audio into Logic or Cubase
- Mr Arkadin
See my response in http://www.planetz.com/forums/viewtopic ... forum=14&1
