Shayne
Noah for OSX!! (No, I'm not kidding...)
Shayne White
Shayne White
PCI? why is it a problem. it works through USB (on the Mac Keyboard). I've seen it in action under Mac OS X and it works just like on pc.
If the pci was refering to the fact that it is not a great audio card, well, that's true, but I think Noah serves another purpose, it's not really a soundcard, but a synth with some soundcard possibilities. But Ithink you can do a live audio project on a few audio tracks (like 8 tracks) plus the rest in midi/live and it's fine.
I had nothing to do, so I thought i could give my 2 cents...
in the SoS review of SFP, it was mentioned that SFP4 (or whatever they will name it), including OSX support would be here in the last quarter of 2003.
OSX is around for quite some time now. the CW soft had to be 'completely' rewritten to run it under OSX (which they were working on). a big job, i guess, so i don't think they just stopped development when the G5 with it's new specs was announced.
but don't take my word for it... i just tell what i heard/read.
andy
the lunatics are in the hall
Shayne White
I don't have Noah, but I downloaded the software to see how it looked on screen. It looked very good. It had none of the graphics wierdness that the first Macintosh Pulsar software had in OS9. All of the knobs and sliders seemed to work okay. The inserts worked very well in the Noah mixer. It gave me hope that SFP4 for OSX might actually come before the end of the year.
a bit OT, anyway, a friend of mine says CW should make a external box for the card to run in, and chain it to the mac by firewire.
This way you're independent from hardware devellopments inside the computer, you can easily use it with powerbooks, you have better hardware In/Out facilities, etc.
Is firewire a good and fast technic to do this?
Let There Be Music!
<font size=-1>[ This Message was edited by: hubird on 2003-09-23 21:26 ]</font>
Let There Be Music!
THE END?? I'm sure we haven't seen even the beginning yet! Well, not quite sure but hope so.I'm sure we haven't seen the end of Noah yet...
Too bad they don't tell exactly what has changed in that software.. Okay, it's only the "SFP-side" of NOAH. I'm waiting desperately for firmware upgrade on HW side.
<font size=-1>[ This Message was edited by: spoimala on 2003-09-24 03:53 ]</font>
1. Noah changes with v1.1 - Overview
In the following text, Noah Remote Software is referred to simply as „NRS“.
- There is now an ASIO driver which is capable of 2-channel playback and 6-channel record.
- There is a new Parameter Lock function which permits you to „freeze“ the selections of various inputs and outputs independent of presets.
- Preset names now appear immediately in the Noah display upon selection in NRS.
- Assignment of multiple mixer outputs to a single mixer channel is now also possible in NRS. The corresponding input(s) are indicated by a point in the selection list.
- In the mixer, the analog input can now be switched to two mono channels, so that mono signals can be more conveniently controlled (guitar, microphone, etc.)
- The B-2003 rotor has a new „Distance“ parameter.
- The acceleration behavior of the Performance Controllers can be adjusted separately per controller.
- The footswitch can now be used for preset switching.
- USB and MIDI can now be simultaneously set as MIDI In ports (all).
- General performance and loading-time optimizations for devices and graphics.
- The sizes of preset files have been reduced.
- The number of voices is now displayed via the Live Bar.
- NRS checks the Noah OS version upon startup.
- The Synchronizer has a new Delete function. Optional addin plug-ins can now be managed without problems.
- In the Noah menu ‘System -> Device’ there is a USBCom parameter [Windows, Mac/Linux] that determines which MIDI driver will be linked in during driver installation. Select Windows for all versions of Windows.
<font size=-1>[ This Message was edited by: grotools on 2003-09-24 07:02 ]</font>
Actually a magma does not quite do that (firewire link) - it does it over PCMCIA or PCI. I guess Magma will update their PCI cards to fit in the G5s. I personally hope that Apple does not phase out the PCMCIA slot on their future powerbooks tho :zOn 2003-09-24 04:29, samplaire wrote:But magma is soooooooo expensiveOn 2003-09-23 22:56, at0mic wrote:
hubird, a magma does just that...
Incidentally, keep an eye on ebay, I've seen Magma's sell for shockingly low prices there
peace
Shayne White
marcuspocus
Firewire1 with 400meg/sec is 3 times faster than PCI (which is 133meg/s in the best mobo that exist).
Firewire2 with 800meg/s is 6 times faster than PCI.
The problem would be addressing the PCI card via a firewire bus. Not speed.
But i would definitely be interessed in a firewire solution for my cw cards.
PCI is 133MB/sec whereas firewire is 400Mb/sec which is 47.6837158203125 MB/sec according to this site: http://cyberwizardpit.net/calc.htm
sorry to be anal
But maybe the firewire 800 may be an option for the new Apple machines.. 95MB/sec should be pretty usable. however.. I don't know if theres much latency etc. involved with addressing this kind of system.. because data would need to be converted between firewire and PCI. For multiple streams this could get unusable.
peace
sorry to be anal
peace
Sir
