On 2003-09-17 20:59, blgrace wrote:
I think the sound of the Pulsar mixer is much better than VST . . but I find I'm using a LOT of audio tracks these days - both samples and bounced tracks - so this doesn't leave me with many options via ASIO to use the pulsar synths as well as using the bussing system. I sometimes run up to 32 tracks of audio - the standard SFP mixer only has 16 stereo channels -
that is 100% true, i don't know why but sfp sounds great... maybe pulsar is dedicated to pro audio and directX/vst is not.
You may not need 32 buses if you share common kind'a tracks to feed each bus. a lot of buses cause me some wired problem. yesterday i did a song something like this:-
*track 1-kick-----Bus1
*track 2-snare----bus2
*track 3-side-----bus2
*track 4-toms-----bus2
*track 5-ride-----bus3
*track 6-ohh/chh--bus3
*track 7-clean gtr rhy/slar(pan left)--bus4
*track 8-clean gtr rhy2(pan right)-----bus4
*track 9-nylon string gtr solo--bus5
*track 10-bass------------------bus6
*track 11-main vocal------------bus7
*track 12-background vocal 1----bus8
*track 13-background vocal 2----bus8
*track 14-harp(very small part)-bus9
*track 15L/R-piano(small part)--bus9
*track 16-strings(soft)--------bus10
*track 17-chime----------------bus11
*track 18L/R-bounce mix--------bus12
thanks.
