any ideaz?
how come asio 24 only 16 (stereo) channels?
oioi
- Mr Arkadin
You really should use the ASIO2-32 Source 64 module (and the corresponding Dest module) even for 24 bit recording, as i think it has newer drivers or something, can't remember the details but the other modules are older. Using this module you can get 32 stereo ASIO channels, which barely fits on my screen! Double click on the ASIO module and try raising the Source Channels number to 64. Whether your sequencer can or not is a different matter
<font size=-1>[ This Message was edited by: Mr Arkadin on 2003-09-14 07:04 ]</font>
- ChrisWerner
Hm, I tried to raise my PulsarI with SRB board to 64 ASIO channels. I haven´t got the ProPack so I had to use a other mixer solution. I loaded two micro mixers with 16 stereo channels each and a additional micro mixer to mix the four mixer outputs to one stereo output.
I thought I had won but after I´ve started my Cubase, my PulsarI surprised me with a PCI overflow,arrgh. I think the PulsarI or my system is to weak to hold all ASIO channels,damn.
Now I use one micro mixer with 16 32bit ASIO channels (stereo) again. I mix and master in Cubase only and use Pulsar for routing and to play the Pulsar synths. 8 DSP´s are not much on a Pulsar I + SRB.
